Products aren't displayed as the same size
12 years 1 month ago #167710 by samuel
-- url of the page with the problem -- : www.lockharttactical.com/
-- HikaShop version -- : 3.x
-- Joomla version -- : 3.x
As you can see on the pages below, the product divs are quite different. I dont know why they dont all just display as the same size? What do i need to correct to fix this?
Problem A
Sections affected:
1) FEATURED PRODUCTS on url: www.lockharttactical.com/
2) Entire page: lockharttactical.com/product
3) Entire page: lockharttactical.com/recent
Problem B:
imgur.com/mOEGCrO
At the top of ALL pages, as soon as you ADD at least 1 product to the cart, the proceed to checkout button appears.
But the button appears BELOW the rest of the mini cart in the top. How can I forced the "PROCEED BUTTON", to appear directly to the RIGHT side of the mini cart?
Thanks so much.
12 years 1 month ago #167721 by nicolas
If you want to force the height of all the product boxes to be the same, you need to add such CSS on your website:
.hikashop_subcontainer{ height: 250px !important; }
For the proceed to checkout button, you need to add some float:left; and display:block; to the two texts before the button and it will display on the same line.
The following user(s) said Thank You: samuel
12 years 1 month ago #167815 by samuel
imgur.com/vo0IChW
Here is an image of what happened with that css for the box sizes. The images and prices, and product name etc, didn't seem to be in the boxes. etc. Very strange.
And i apologize, but for the 2nd codes you gave, i tried using " float:left; and display:block;" im not sure what to exactly target.
Thanks again so much. you guys are amazing. Im always recommending hikashop to everyone i meet in business.
12 years 1 month ago #167828 by nicolas
For example such such should make the button on the same line:
.hikashop_cart span{ float:left; display:block; }
12 years 1 month ago #167933 by samuel
imgur.com/q9NarZi
This did help!
Thank you very much.
What im really trying to do.. is make the header smaller (vertically)
Right now, there is a big gap under the "proceed to checkout button" and where the top of the main menu starts.
Can hikashop automatically make the button much slimmer. and make the "cart icon, and price etc" more inline instead of stair casing?
Thanks so much. I really do appreciate all the help you guys provide.
12 years 1 month ago #167941 by nicolas
The button styling and the header of your website are both handled by your template CSS. So I would recommend to contact your template provider for help on this.
12 years 1 month ago #168094 by samuel
1) .hikashop_subcontainer height: 250px !important; }
I added this CSS, but it seemed to distort the page. The product boxes get larger, but it forces the product name and price far below it.
It makes it 100% un-read able: Please see this img: imgur.com/1KZ6vMo
2) www.lockharttactical.com/component/hikas...lic-safety-toe-boots
On product pages I am still trying to get the codes to display properly for the "Price: "xxxx" per unit"
can you please help me again?
thanks!
3) I want to delete specifications tab, as now it is pointless as i have moved the "brand" button from the specs tab to the main product page layout. I would also like to combine the COMMENT and POST A COMMENT tab,
Thanks!
12 years 1 month ago #168120 by nicolas
1. Change the height to adapt it to your website. 250px was just an example.
2. and 3. You can edit the file "show_tabular" via the menu Display>Views for that.
Time to create page: 0.238 seconds
