Products not showing on category and vice versa
12 years 1 month ago #169023 by bettston
-- url of the page with the problem -- : www.chs-ironmongerydirect.co.uk/
-- Joomla version -- : 3.3.1
I know this is a common issue and I hope is a setting but I cannot figure it out
If you go to the website home page and click any of the categoriy icons showing in the middle you get sub categories no problem but when you get to where the products should display you just get the intro text if there is any.
Also if you use the menu a the side and go to a category from the home page its blank but if you then goto the productts a second time they are there but if you then try to go to a category page that does not show the sub categories anymore.
Its driving me mad
any help please, I have tried all sorts of settings but to no avail.
Tony
12 years 1 month ago #169070 by Mohamed Thelji
Hello Tony,
No products are displayed because you probably don't have any "Associated module" through your category listing content menu which have the ID number 101, you can check it through the your category listing configuration page ("Hikashop->Display->Content menus->'YourCategoryListingMenu'").
12 years 1 month ago #169081 by bettston
thanks, I have nearly gt it fixed, the products show corctly now however if I select a product category from the left menu
www.chs-ironmongerydirect.co.uk/index.ph...sting/73-escutcheons
I get the 2 products but below I get this module showing every product. Where or how do switch that off?
thanks
Tony
12 years 1 month ago #169087 by Xavier
It's the module with the id "141", so you have to disable it, or remove the association in the left menu settings.
Time to create page: 0.182 seconds
