- Thank you received: 1
Product description only on right side?
12 years 3 weeks ago #171009
by wayneft
Product description only on right side? was created by wayneft
-- Joomla version -- : 3.3.3
For some reason when I add the description to every product page, all the text is set into a column on the right half of the product page (see picture)? If I set the display to Reversed the description text is moved to the left as it should but the product image is also reversed (which I do not want to do). It is also formatted correctly if I use the Tab option to display. After watching the tutorials and seeing sample product pages, it does not appear as though what I am see is default. How would I go about changing this?
12 years 2 weeks ago #171034
Replied by nicolas on topic Product description only on right side?
This looks like the product page layout has been customized (either by yourself, or by your template) in order to put the description on the right side of the product page layout instead of having it at the bottom like it is the case by default.
Go in the menu Display>Views and check for the "show_default" view file. If it has been modified from the original, you'll see a bin icon in the "remove customization" column for that view file for your template.
Time to create page: 0.161 seconds
