Product "Options" appearing in Product Listings
- kyteasdale
11 years 11 months ago #175440
by kyteasdale
Product "Options" appearing in Product Listings was created by kyteasdale
Hi There - I have all my Options saved in an unpublished category under the root folder. However I keep seeing them appear in my product listings - just a random Size - £5 amid the other products.
Plus they get inserted to the google feed.
how can I stop one or both of these problems?
11 years 11 months ago #175445
Replied by nicolas on topic Product "Options" appearing in Product Listings
If you create a products listing of all the products under the main category and that under that category you have an unpublished category, the products under that unpublished category will still be taken into account and displayed.
You really need to put that unpublished category outside of your main tree of categories so that the products below it won't be taken into account on the products listings.
That's probably what is happening here.
Regarding the google feed, it indeed takes into account all the products, even the option ones. We'll fix that for next version of HikaShop which is to be released this month.
- kyteasdale
11 years 11 months ago #175529
by kyteasdale
Replied by kyteasdale on topic Product "Options" appearing in Product Listings
Thanks for the response - looking forward to the new version
I'm afraid I may not have been clear. My options folder is directly under ROOT, and all the products are in folders under Product Category. The options aren't in any authorised folder
11 years 11 months ago #175540
by Xavier
Replied by Xavier on topic Product "Options" appearing in Product Listings
So your tree is :
Root
Options - Product Category
In the options of your menu/module, for the category option have you selected "product category" ? If it is, the products of the options should not be displayed.
It you have that set up like this, but still the issue you can give us a backend account via private message or via our contact form.
Don't forget to give the url of that topic.
So your tree is :
Root
Time to create page: 0.173 seconds
