How to enable comment on Default Layouts?
- magicwords
-- Joomla version -- : 3.3.2
-- PHP version -- : 5.5.15
I have enabled the 'Layout on product page' as 'Default'
Earlier it was in 'Tabular' layout and the comment tab was displayed. But now since I had changed it to 'Default' I can't see any link or button for users to add comments.
Please guide. Thanks in Advance
Please check your settings in Configuration > Features > Votes & Comments
- magicwords
Can you please read my query once again? I know this path Configuration > Features > Votes & Comments
But my question was how to """ENABLE""" them in 'Default' type of product layout. Earlier when I had set the product layout as "Tabular" the comment tab was visible. But when I changed from "Tabular" to "Default".... now it is gone. In product layout there are three options 1) Default 2) Reversed 3) Tabular. So the commenting works only with option 3 i.e. Tabular.
I hope you get what I mean.
So I want to enable the commenting for all the layout options which I can't see anywhere in the path you gave.
If you enable the comments in the previously indicated section in the configuration, so that should be displayed on all the views.
In your case, if you have enabled it, so you have potentially an override on the view "product / show_default" and in this override the comment part has been removed.
Please backup your view, and reset it by clicking on the dustbin in the views listing via the menu Display > Views.
If you don't have overrides, please give us a screenshot of your comment settings in the configuration.
- magicwords
Xavier wrote: Hi,
Hello, please find the attached screenshots of 1) Votes & Comments settings 2) Product Display settings from configuration.
You just have to enable the first option which allow to display vote (and comments) on the product page.
I will change this translation now, it's not clear enough.
