Products in articles displays the same category
11 years 10 months ago #179194
by Jeyjoo
Products in articles displays the same category was created by Jeyjoo
innovazionitecnologiche.it
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.30
-- Browser(s) name and version -- : Firefox latest
-- Error-message(debug-mod must be tuned on) -- : No error
I am using short codes like the one below to display Hikashop products directly in articles.
Problem - the products display correctly (with title, image and price), but the link given is incorrect (the category never changes).
I have created a quick example page here . These products should all be in different categories, yet the category url it always tecnologie-viso-corpo
Any ideas
Any ideas
11 years 10 months ago #179218
by Jerome
Replied by Jerome on topic Products in articles displays the same category
The category and the url are two things different.
If you want to have nicer and more personalized url for your products, the best is to use the canonical url.
11 years 10 months ago #179296
by Jeyjoo
Replied by Jeyjoo on topic Products in articles displays the same category
Hi Jerome thanks for the reply,
So are you saying that I should:
- removed the personalised URL (which takes the Joomla menu alias + product name and number )
- change every single product url to add in a category + product name in the canonical url field?
This seems an inefficient way of creating each product link - is that the best way to set up Hikashop store? Especially if a shop has a lot of products and categories, when a category name gets changed, I would have to pass through each product and manually change the category or do some htaccess rewrites (which is not ideal).
11 years 10 months ago #179337
Replied by nicolas on topic Products in articles displays the same category
The product tags have an attribute you can use in order to specify the menu item you want to use for the link to the product page.
If you don't specify any, it will use the first one it finds and thus the category used in the url might not correspond to the category of the product (that's why there is this option). However, the canonical URL of each product allows you to define the URL you want to use for each product.
11 years 10 months ago - 11 years 10 months ago #179415
by Jeyjoo
I am not sure I follow. You mean that within the code below, I can specify the correct category?
Already each product has been given a specific category on the product page.
Last edit: 11 years 10 months ago by Jeyjoo. Reason: Missed a line
- Thank you received: 1778
11 years 10 months ago #179438
by Mohamed Thelji
Replied by Mohamed Thelji on topic Products in articles displays the same category
Nicolas was talking about the "Menu ID" option of the "Product" button popup. However, the product tag plugin doesn't use the product canonical URL so I'll edit the code of that plugin to correct it
I'll post the last plugin version after the modifications/tests.
11 years 10 months ago #179534
by Jeyjoo
Thanks Mohamed. Any time frame on the update?
11 years 10 months ago #179793
by Mohamed Thelji
Sure, I'll start it monday and give you the last version through that thread
11 years 10 months ago #180189
by Mohamed Thelji
Can you test it with that last plugin version ?
Also note that you should set the canonical url option of your products or set the "Force canonical URLs on listings" option to Use canonical URL if specified via "Hikashop->System->Configuration->Features".
11 years 10 months ago #180445
by Jeyjoo
Thankyou Mohamed the updated plugin did the trick, though I have a separate issue in that whenever I set canonical URL, I get a 404 error. I opened a thread here:
www.hikashop.com/forum/product-category-...orrect-category.html
Do you have any idea on how to resolve this?
11 years 9 months ago #182811
by Jeyjoo
Hi Mohamed,
Is there a way to get this to work without forcing canonical? I have been advised to not force canonical due to 404 errors.
There are two examples of this module on this page - innovazionitecnologiche.it/news/guida-al...ta-per-i-piedi-detox
Both links give 404 as they are missing the /shop/ extention on the url after the .it and before the category.
Any way around this (I would like to get Hikashop working correctly rather than add in a htaccess rewrite).
11 years 9 months ago #182850
by Mohamed Thelji
To do that the only solution will be to manually add canonical URLs through the "Canonical URL" option of your products configuration page.
The following user(s) said Thank You: Jeyjoo
Time to create page: 0.243 seconds
