Hikaserial code not applied to product cust field
11 years 10 months ago #180518 by nowherenowhere
Okay so its a bit of a tricky one here. I have products with a custom field in the item.type
I also have Hikaserial applying a code to each product as its bought.
The problem is, if I adjust the custom field from option 1 to option 2, the serial code is not being applied to the second option of the product... How can I get this working?
TX
Believe in Better
11 years 10 months ago #180524 by nowherenowhere
Ah, let me rephrase that...
Actually whats happening, is this field is being called in the product listings view. Then if I toggle the options and choose the second one and go through checkout, it is not being applied to the product (the serial number) // which means I dont see it in the order created email... However if I go through to the product page and apply the second option - it is applied to the product - and I see it in the order created email.
So for some reason the option although it displays in the product listing and it goes reflect in the text if I select it (reflect in the text of checkout) - the actual serial is not applied... Is there something I can add to the product listings view to ensure the serial is applied if a custom field option is selected?
Believe in Better
11 years 10 months ago #180527 by nowherenowhere
What a truly wonderful component you guys have made! - For anyone who has the same issue, this is your salvation:
HikaShop serial product-add check
In da plugins!
Believe in Better
Time to create page: 0.164 seconds
