- Thank you received: 92
bootstrap 3 thumbnail images overlap issue
11 years 10 months ago #181111
by lionel75
bootstrap 3 thumbnail images overlap issue was created by lionel75
-- HikaShop version -- : 2.5.22
-- Joomla version -- : 2.5.22
-- PHP version -- : 5.3.9
-- Browser(s) name and version -- : many
-- Error-message(debug-mod must be tuned on) -- : copy from another post for ask question
copy from s21rc www.hikashop.com/forum/mass-actions/8716...-address.html#181108
Please have a look www.peak69.com
1. I want to use badges for discount, free shipping, sale etc. As per documentation it seems I need to apply badges on CATEGORY, but creating category will also show those category in my Shop by Category Menu. Is there a way to hide some category (featured, sale, discount, free shipping etc) from showing up from menu and div listing?
2. I am using a responsive theme with Joomla 3. I have set 3 column Div view for listing, Now when I see the category listing from a mobile browser, the thumbnail images (which is set 200px wide) overlaps with each other.
If I set Bootstrap option yes in Hikashop, then from desktop browser only 1 column (in place of 3 column div listing) is coming in Category Menu (mega menu loads a category listing module using DIV view) and in product view for category.
Also the price and add to cart comes over the image thumbnail.
Please suggest a way to optimize it for Mobile version.
Thankyou in advance for your as usual prompt support.
11 years 10 months ago #181112
by lionel75
Replied by lionel75 on topic bootstrap 3 thumbnail images overlap issue
jerome
Your new questions are quite far from the original thread.
Please, for your new questions, open new threads ; otherwise it won't help other users while searching answer for same kind of things.
1. Just unpublish a category to hide it.
2. Your template is bootstrap 3 compatible. HikaShop is Bootstrap 2 compatible (due to Joomla specifications).
So for the moment, if you want that HikaShop be bootstrap 3 compatible, you have to override some HikaShop views in order to replace the bootstrap 2 classes into bootstrap 3 classes.
The Bootstrap 3 support is planned for HikaShop 3.0
HikaMarket & HikaSerial developer / HikaShop dev team
11 years 10 months ago - 11 years 10 months ago #181113
by lionel75
@jerome
a) when you write override view you have in mind php file locate in component or module ?
b) Hikashop has an option to enable bootstrap . Is there an option to select bootstrap version
2.x or 3.x and let hikashop select default 2 if 3 is not available when site configure to use 3 ?
c) does mass action can work on php file to this task ?
i don't know if this task has been resolve by @s21rc . but override mean create new php file ( not html) and change bootstrap selector name ( but not only..hiearchy script ) . Google we help us to find tool instead use batch replace/regex tool : code.divshot.com/bootstrap3_upgrader/
regard's
@jerome
regard's
Last edit: 11 years 10 months ago by lionel75.
11 years 10 months ago #181215
Replied by nicolas on topic bootstrap 3 thumbnail images overlap issue
As jerome said, hikashop will support both bootstrap 2 and 3 in the future and yes it will be with a version selection dropdown in the configuration. But for now it only supports bootstrap 2 so it's up to you to modify the code of the views if you want to support bootstrap 3.
Mass actions won't help here.
Time to create page: 0.161 seconds
