popup problem
11 years 8 months ago #187451 by jesper
popup problem was created by jesper
-- url of the page with the problem -- : jupitercykler.web10.redhost.dk/udstyr
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.10
-- Browser(s) name and version -- : any
-- Error-message(debug-mod must be tuned on) -- : no error, item gets added to cart and redirect to frontpage
when adding products to cart ("læg i kurv") from category page 2 times using shop on with popup enabled, i get redirected to front page on second add.
i only have this problems sometimes, not every time...
It does not matter i use custom template or protostar on the site.
11 years 8 months ago #187524 by Jerome
Replied by Jerome on topic popup problem
When the page is displayed with the parameter "popup=1" ; the value of the field "return_url" does not contains the current url but it contains the homepage url.
I think the problem is coming from the function "hikashop_currentURL" which has been modified for HikaShop 2.3.5 in order to add more security (and does not allow redirection to external websites).
What you can do for the moment is to edit the file "components/com_hikashop/views/product/view.html.php" and replace
$url = hikashop_currentURL('return_url');
By
$url = hikashop_currentURL();
11 years 8 months ago #187615 by jesper
Replied by jesper on topic popup problem
Changed that file, and i still get same problem.
On first visit i'm on
jupitercykler.web10.redhost.dk/udstyr/pr...-spectra-spd-vendbar
When i then add to cart, i go to url
jupitercykler.web10.redhost.dk/udstyr/pr...-spd-vendbar?popup=1
If i then click "shop on" and add to cart again, i get redirected to
jupitercykler.web10.redhost.dk/index.php?popup=1
so problem is still not solved.
11 years 8 months ago #187636 by Xavier
Replied by Xavier on topic popup problem
What is this "shop on" ? Does that redirect to a page with a correct url ?
The page is protected by password, so we can no more see the issue, please give us the login details.
Time to create page: 0.172 seconds
