Display product total vote
11 years 8 months ago #188832
by gioxd
Display product total vote was created by gioxd
www.laputea.com/it/negozio/prodotti-piu-venduti
-- HikaShop version -- : 2.3.5.
-- Joomla version -- : 3.3
i've a "little problem". I activated a module to display the top rated products, and I want to show only 20 products.
Now, the problem is this.
If in the "Number of objects" insert 20, appearing 20 products, but with the pagination layout that shows all products and show 20 products in first page! See screenshot.
If I put "random objects" I see only 20 products (good!), but not products Top Rated (why??)! Yes, are random object, but not among the most voted!
The question is: how can I show only 20 products (without showing the function HIKA_PAGINATION)?
Thank You!
P.S. how i can modify the translation of "Display Num"? In the box of language translate i don't find. Thank You
Thank You!
11 years 8 months ago #188835
Replied by nicolas on topic Display product total vote
If you don't want any pagination, you can turn it off in the Display tab of the HikaShop configuration.
If you don't want the pagination only on one listing of products, then I would recommend to one a products listing module instead of a menu.
For example, the "Best rated" module which was added by HikaShop when you installed it which is already preconfigured in order to display best rated products.
You can change any text with a translation override:
That text coming from Joomla, you should use the Joomla translation override system in order to find it.
The following user(s) said Thank You: gioxd
11 years 8 months ago #188968
by gioxd
Replied by gioxd on topic Display product total vote
Hi Nicolas, thanks for the reply.
I Don't want to turn off the display in "Global Configuration", otherwise it off everywhere.
In fact I'm just using the native module of hikashop to display the top rated products. My question is, how do I disable the display in that module?
11 years 8 months ago #188993
On the link you gave it seems that you have a product or category listing menu item where you added the best rated module as an associated module.
When a module is displayed as an associated module, it will display the pagination if possible.
So instead of doing that, create a menu item of another type, for example, an empty article menu item and configure the best rated module via the Joomla modules manager to display only for that menu item in a central bottom position of your template; or display it inside the joomla article with a loadposition tag:
www.ostraining.com/blog/joomla/loadposition-loadmodule/
11 years 8 months ago #189039
by gioxd
You'Re Good! I never thought of! I will do so!
Time to create page: 0.191 seconds
