Shifting location of prices display
11 years 8 months ago #188924 by LAMF
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.5.19
-- Error-message(debug-mod must be tuned on) -- : No error
HI,
I want to shift location of the prices, see attached image.
What I want is the original per piece price including VAT to be displayed on top and then underneath I want rebated price (like if you buy 10 pcs you shall have discount).
The file to edit must be the Display => Product => listing_price
But I don't know how to set it up like I want it displayed.
Thanks for any help here.
11 years 8 months ago #188938 by nicolas
I would need more information first. How did you configure your prices ? Could you do a screenshot of the product edition page of one product ? You're talking about a rebated price. Did you setup a discount ?
Are you able to purchase products by units, or only by 10 pcs ?
11 years 8 months ago - 11 years 8 months ago #189075 by LAMF
HI,
I have set it up like ordinary price when buying 1 piece up to 11 pieces then discount 20% when buying 12 pieces or more.
Set up like the screenshot here:
Oh by the way is it also possible to display prices with decimals only when the price has decimals to display like 11,34 kr and no decimal when price is like 12,00 kr or anything with ,00?
Last edit: 11 years 8 months ago by LAMF. Reason: More information added
11 years 8 months ago #189103 by nicolas
Ok, thank you for the information.
Then, edit your menu via the menu Display>Content menus and set the "prices display method" option there to "all" and that should do what you want.
For the decimals there is no option for that. You would have to edit the file administrator/components/com_hikashop/classes/currency.php and change the line:
return $format;
return str_replace(',00','',$format);
11 years 8 months ago - 11 years 8 months ago #189176 by LAMF
HI,
Ok tried that but that make ti display all prices for the products listed..Not quite as I wanted.
I would have liked it to display on top the original per piece price and under that the price per piece when buying 10 or 12 or whatever options there are.
It is a css styling thing but I don't seem to be able tp get it working...
There are two css classes:
.hikashop_product_price_with_min_qty .hikashop_product_price_for_at_least_12 and I have tried to set those up so there should be a line break between the price for 1 item and the price for buying for i mthis example 12 ut it does't seem to work.
I applied it in the css file style_red.css under System => Display
Any help please...
The decimal issue was greatly solved! Thanks for that!
Last edit: 11 years 8 months ago by LAMF. Reason: more info added
11 years 8 months ago - 11 years 8 months ago #189183 by nicolas
I would love to help but before that I would need to understand what you want, because I thought that your question was about displaying all the prices of the product on the listing.
If that's not what you want, then I still don't know what you want and I can't answer to a question I don't know.
If you have two prices (1 for the quantity for 1 to 11 and 1 for the quantity above 12) then setting the option like I explained will display both prices, which is what you said you wanted:
So if that's not what you want, please explain what you want.
Last edit: 11 years 8 months ago by nicolas.
11 years 8 months ago #189254 by LAMF
You're totally right and it is exactly ehat I want. So now it has turned into a styling issue I can't solve.
I would like the Price for 1 pc to 11 (in this example) to display above the price for 12 pcs anmd more.
Like the picture I have in my first post. Is that possible?
Like it is displaying now they are all in one line but they ar estill defined as different elements so I would need some styl,ing help, i.e. some css to make it displaying as I want.
Like this:
11 years 8 months ago #189277 by Mohamed Thelji
Can you give us a link to the page where you are having that issue so that we can directly test it ?
11 years 8 months ago - 11 years 8 months ago #189345 by LAMF
I set it to only display price for one product but on this specific page I have set it up to display all prices so you can test:
www.dsgbutiken.com/index.php/tillbehor-bil-lastbil/olja-filter
11 years 8 months ago #189352 by Xavier
You will have to edit the view "product / listing_price" and replace the line:
echo '<span class="hikashop_product_price_per_unit">'.JText::_('PER_UNIT').'</span>';
By:
$maxQuantity = $price->price_min_quantity - 1; echo '<span class="hikashop_product_price_per_unit">'.JText::_('PER_UNIT_UNTIL_X_BOUGHT',$maxQuantity).'</span>';
And add a translation override like:
PER_UNIT_UNTIL_X_BOUGHT="Price for 1 - %s"
And you can override the translation:
PER_UNIT_AT_LEAST_X_BOUGHT="Price for %s and more"
www.hikashop.com/support/faq.html#tran
11 years 8 months ago #189491 by LAMF
HI,
Thanks for giving me the code, it works!
Now it's the styling to get the price for at least x on the row under the price for one.
I want that price in smaller size as well so the regular price is displayed on top like my example.
I don't get it working when trying to style it in the css file style_red.css
Any help appreciated.
Thanks!
11 years 8 months ago #189503 by Xavier
Please try to apply the properties on the class:
.hikashop_product_price_with_min_qty{ display: block !important; font-size: 12px !important; } .hikashop_product_price_with_min_qty span .hikashop_product_price{ font-size: 12px !important; }
These properties needs to be added at the end of the style_red.css file.
The following user(s) said Thank You: LAMF
11 years 8 months ago #189599 by LAMF
Thanks that was the key!
I wanted the second price a bit smaller so I added a new style to that so now it'sworking perfect.
.hikashop_product_price_with_min_qty{ display: block !important; font-size: 12px !important; } .hikashop_product_price_with_min_qty span .hikashop_product_price{ font-size: 16px !important; } span.hikashop_product_price.hikashop_product_price_1 { font-size: 12px !important; color: #D00; }
Time to create page: 0.280 seconds
