- Thank you received: 1
Product Quantity Field not showing on product page
11 years 7 months ago - 11 years 7 months ago #190955
by Huski
Product Quantity Field not showing on product page was created by Huski
I have no idea if I have done something or there is an issue somewhere but the product quantity field that normally sits next to the Add to Cart button has disappeared.
Any ideas?
www.ecomad.com.au/ecomad-Rasa/hikashop-m...e-520/eco-seal-white
Any ideas?
Last edit: 11 years 7 months ago by Huski. Reason: added link to website
11 years 7 months ago #191001
by lousyfool
Replied by lousyfool on topic Product Quantity Field not showing on product page
Check your settings for the quantity field. Here are all the options that have anything to do with it:
- -> System -> Configuration -> tab Main -> Product -> option "Display the quantity field on the product page"
- -> System -> Configuration -> tab Display -> Default parameters for products -> option "Quantity layout on product page"
- Both options as above on each product edition page
- Only for product listings, there is also the option "Quantity field on 'Add to cart' button" in the configuration of all your product listing menus/modules.
11 years 7 months ago #190958
Replied by nicolas on topic Product Quantity Field not showing on product page
You must have changed the option "Display the quantity field on the product page" of the HikaShop configuration.
11 years 7 months ago #191019
by Huski
Replied by Huski on topic Product Quantity Field not showing on product page
Thats it - thanks - dont remember touching that
