Custom Fields - Required yes, but must choose
- nowherenowhere
11 years 7 months ago #191371
by nowherenowhere
Believe in Better
Custom Fields - Required yes, but must choose was created by nowherenowhere
Hi Guys,
I have required custom fields on order, they are 2 drop downs, but I need that user must make a choice for them to proceed.... so at the moment although they are "required fields" it's just defaulting to the first option.... It mustnt happen - how to get it like that?
Believe in Better
11 years 7 months ago #191397
by Jerome
Replied by Jerome on topic Custom Fields - Required yes, but must choose
If the value of the selected element is empty, HikaShop will consider that the field is not fill so it will refuse it.
After that, we will need more details if you want us to help you correctly.
Time to create page: 0.154 seconds
