Paging between products
- conlippert
11 years 7 months ago #193006
by conlippert
Paging between products was created by conlippert
maltusa.com/j3-test/index.php/malts/product/2-durst-vienna-malt
-- Joomla version -- : 3
Hi, I can't seem to get the paging between products to show up. Need "Next" and Prev buttons but can't seem to find where they are turned off. Thanks for your help
11 years 7 months ago #193055
by lousyfool
Replied by lousyfool on topic Paging between products
See the option "Show shortcuts to other category product" here: www.hikashop.com/support/support/documen...tml#display_products
- conlippert
11 years 7 months ago #193153
by conlippert
Replied by conlippert on topic Paging between products
The "Show shortcuts to..." is set to "Yes" but the next/prev buttons are still not showing.
11 years 7 months ago #193204
Replied by nicolas on topic Paging between products
The buttons will be displayed automatically if you have other products in the same category as the category of the product.
If that's the case and you still don't see them, then it means that either the product layout has been modified (by you or your template provider) and removed the code to handle that, or more likely that you have some caching on your website preventing you from seeing the change. In that last case, clearing the Joomla cache should fix the issue.
- conlippert
11 years 6 months ago #193770
by conlippert
I cleared the cache and tried again. There are products in the categories. My CSS template in the configuration is set to none because I want to set my own styles according to my template. Still no paging.
11 years 6 months ago #193772
by lousyfool
Aaaah, that explains it. By default, the images for pref/next product are inside a sprite and loaded via CSS.
You have options: either edit the relevant view and put in your own buttons or images, or do so via your own custom CSS, or consider using the CSS from HikaShop's frontend_default.css:
Hint: If you have CSS set to "None" and anything looks strange or doesn't display, activate the default CSS at least temporarily - then you'll probably find the solution quite often yourself...
conlippert wrote: My CSS template in the configuration is set to none because I want to set my own styles according to my template.
.hikashop_previous_product{
background-color: transparent !important;
float:left;
width: 6px;
height: 6px;
background:url(../images/icons/nav_products.png) no-repeat 5px -20px;
margin-bottom:10px;
padding:5px;
border:1px solid #ddd;
border-radius:3px;
margin-right:4px
.hikashop_previous_product:hover{
background:url(../images/icons/nav_products.png) no-repeat 5px 3px;
.hikashop_next_product{
float:left;
width: 6px;
height: 6px;
background:url(../images/icons/nav_products.png) no-repeat -30px -20px;
margin-bottom:10px;
padding:5px;
border-radius:3px;
margin-right:4px
.hikashop_next_product:hover{
background:url(../images/icons/nav_products.png) no-repeat -30px 3px;
Time to create page: 0.216 seconds
