mini cart and normal cart
11 years 6 months ago - 11 years 6 months ago #195019 by nokki00
-- Joomla version -- : 3.4.0
-- PHP version -- : 5.4
-- Browser(s) name and version -- : any
I would really like to use ajax feature when adding products to mini cart and updating the quantity and price with non mini cart. I have both module type enabled and when ajax is enable only one updates. Now i was ok with just letting the browser refresh but then when i click on add to wish list it gives me a message in a green box and It is better to have ajax to handle "need to login first" message.
How can i get the mini and normal cart to update with ajax when both modules are enabled?
Last edit: 11 years 6 months ago by nokki00.
11 years 6 months ago #195067 by nicolas
Replied by nicolas on topic mini cart and normal cart
It would require rewriting the whole add to cart system as it is not made to handle that. So I don't recommend it unless you're really skilled in programming.
We're actually starting work on rewriting the add to cart system so that it can handle that (and much more). It's going to take many months until we have something ready but it should happen this year.
In the mean time, I can only recommend to keep that ajax option off if you want several cart modules on the page.
The following user(s) said Thank You: nokki00
11 years 6 months ago #195143 by nokki00
Replied by nokki00 on topic mini cart and normal cart
That is good to hear. I will check back later in the year on that.
11 years 6 months ago #195322 by nokki00
Hey Nicolas
I notice that the option that i was referring to stated "Use AJAX when possible for add to cart buttons". I guessing that this is only talking about add to cart only. The problem is when I have it off and I click on wishlist icon without being signed in I get
"Message You must be logged in to use the wishlists."
in the joomla message area.
When I have it on i get a pop up notice which I prefer. Although I don't want it on because how I have my cart updating information with the browser refresh. Shouldn't I be able to have "Use AJAX when possible for add to cart buttons" disabled and still have ajax handle the wishlist popup notice?
11 years 6 months ago - 11 years 6 months ago #195380 by Xavier
Replied by Xavier on topic mini cart and normal cart
This will require the edition of the file "administrator/components/com_hikashop/controllers/product.php" function "updatecart()" in order to replace the code:
$app->enqueueMessage(JText::_('LOGIN_REQUIRED_FOR_WISHLISTS')); $app->redirect( str_replace('&popup=1','',$_SERVER['HTTP_REFERER']));
By a code displaying a popup.
Last edit: 11 years 6 months ago by Jerome.
11 years 6 months ago #195489 by nokki00
Are you saying that the code should replace ?
echo '<textarea style="width:100%" rows="5"><a class="hikashop_html_add_to_cart_link" href="'.HIKASHOP_LIVE.'index.php?option='.HIKASHOP_COMPONENT.'&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id='.JRequest::getInt('cid').'">'.JText::_('ADD_TO_CART').'</a></textarea>';
or add it under that code?
function updatecart(){ $app->enqueueMessage(JText::_('LOGIN_REQUIRED_FOR_WISHLISTS')); $app->redirect( str_replace('&popup=1','',$_SERVER['HTTP_REFERER'])); echo '<textarea style="width:100%" rows="5"><a class="hikashop_html_add_to_cart_link" href="'.HIKASHOP_LIVE.'index.php?option='.HIKASHOP_COMPONENT.'&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id='.JRequest::getInt('cid').'">'.JText::_('ADD_TO_CART').'</a></textarea>'; }
11 years 6 months ago #195505 by Xavier
You can indeed replace directly the first code, it will be easiest and in a view.
To check if the user is logged in, you can use:
if(hikashop_loadUser() == null){ // display the popup }else{ // default code }
11 years 6 months ago - 11 years 6 months ago #195733 by nokki00
Thanks for your help but still no go
In the file of "administrator/components/com_hikashop/controllers/product.php"
I have
function updatecart(){ if(hikashop_loadUser() == null){ $app->enqueueMessage(JText::_('LOGIN_REQUIRED_FOR_WISHLISTS')); $app->redirect( str_replace('&popup=1','',$_SERVER['HTTP_REFERER'])); }else{ echo '<textarea style="width:100%" rows="5"><a class="hikashop_html_add_to_cart_link" href="'.HIKASHOP_LIVE.'index.php?option='.HIKASHOP_COMPONENT.'&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id='.JRequest::getInt('cid').'">'.JText::_('ADD_TO_CART').'</a></textarea>'; }
Just to make sure. I want to wishlist notification to pop with the message vs it displaying in the joomla default message box. Is this what the code should look like?
11 years 6 months ago #195751 by Jerome
Replied by Jerome on topic mini cart and normal cart
I guess that Xavier was a little bit tired ; he gave you the wrong file to edit.
It is not "administrator/components/com_hikashop/controllers/product.php" but it is "components/com_hikashop/controllers/product.php"
Where the code of the function "updatecart" is really really different !
11 years 6 months ago - 11 years 6 months ago #195766 by nokki00
No worries although in the new file that I am editing I am not sure what to edit.
From the suggestion that Xavier mentioned
I have
function updatecart(){ hikashop_nocache(); if(hikashop_loadUser() == null){ $app->enqueueMessage(JText::_('LOGIN_REQUIRED_FOR_WISHLISTS')); $app->redirect( str_replace('&popup=1','',$_SERVER['HTTP_REFERER'])); }else{ // default code
with a closing bracket ending right before the download function.
} function download() { $file_id = JRequest::getInt('file_id'); if(!$file_id){ return false; } $fileClass = hikashop_get('class.file'); $fileClass->download($file_id); return true; } }
Is that right? if so when I click on wishlist i get blank page of domain.com/product/updatecart. If not can you reply the way the code should look?
11 years 6 months ago #195786 by Jerome
I'm sorry but it's not that ; you're going in the wrong direction and you didn't understand the Xavier messages (and I can understand that, he didn't gave you the right file).
Please just focus on the two lines he wrote in his first messages ( #195380 ) ; just them and not the rest of the code.
It's not that I want to discourage you but if you don't understand the code it will be even more complicated to modify it to change the default behavior.
More than that, change the process and generate dynamically a popup instead will be quite complicated and it require some development time (hours, not minutes).
It might affect some other files/view and I not sure myself that it's already possible with the current code ; specially with the fact that HikaShop can handle different display modes depending the context.. And you have to provide some result which will work for all of them....
11 years 6 months ago #195851 by nokki00
I think hikashop has a lot of potential and has many features. I really like what you guys are doing and hope to see more features in the future. When I asked the question I didn't think it was going to be this much trouble. If can't be done with a simple code modification it's cool not all request can.
I'm just trying to get the mini cart and regular cart to update via ajax. When I was told hikashop doesn't work that way and maybe in the future. I decided to use the page refresh which is just fine.
Then I notice that the wishlist wasn't working via ajax or after refresh popping up with a message stating you need to log in first. I wanted to see if I can do with a simple modification but it appears it will take a lot of code rewrite or code additions to hikashop.
Thanks for the responds and the help on this I will make the best out what I have to work with.
Time to create page: 0.335 seconds
