- Thank you received: 7
Two canonical URLs for same product page
11 years 6 months ago #195167
by boopoo
Two canonical URLs for same product page was created by boopoo
-- Joomla version -- : 3.4.0
Hi there,
When I look at the page source, I see that I have two canonical URLs for each product page.
The actual product page is of course a canonical but then also when you add a product to the cart the URL changes to www.mysite.fr/online-shop/myproduct?popup=1 (with '?popup=1' being added to the URL due to the popup which is used). However this second URLwith '?popup=1' is also treated as a canonical.
Is there an easy way I can stop the '?popup=1' URLs beign treated as a canonical?
Thanks again
Hi there,
Thanks again
11 years 6 months ago #195622
Replied by nicolas on topic Two canonical URLs for same product page
You should disable the system SEF plugin of Joomla via the Joomla plugins manager.
It's the one adding that wrong canonical URL on your page.
11 years 6 months ago #195636
by boopoo
Replied by boopoo on topic Two canonical URLs for same product page
Thank you for that bit of information.
Is the "System -SEF" Joomla plugin linked to the "Search Engine Friendly URL's" in the site settings? Can I disable "System - SEF" without it affecting my "Search Engine Friendly URL's" option in site settings?
Thanks again
Thanks again
11 years 6 months ago #195662
Yes, that should not be a problem.
Time to create page: 0.162 seconds
