- Thank you received: 2
"Custom Fields" don't update on live products
- dancingkazzaf
11 years 6 months ago - 11 years 6 months ago #195558
by dancingkazzaf
"Custom Fields" don't update on live products was created by dancingkazzaf
-- Joomla version -- : 3.4.0
We have a number of custom fields on our product pages, but when we try to change the content inside them they don't update on the existing products.
This is a pain because currently, if we want to change the existing information in them we have to delete and re-upload the product for it to take effect.
Do you have any ideas? I have attached a screenshot of one of the custom fields so you can see our settings.
Last edit: 11 years 6 months ago by dancingkazzaf. Reason: Part of it was incorrect
11 years 6 months ago #195565
by Xavier
Replied by Xavier on topic "Custom Fields" don't update on live products
To change the value of the existing products, we recommend to use the mass actions:
www.hikashop.com/support/support/documen...massaction-form.html
The following user(s) said Thank You: dancingkazzaf
- dancingkazzaf
11 years 6 months ago #196442
by dancingkazzaf
Replied by dancingkazzaf on topic "Custom Fields" don't update on live products
Hi, we've tried using mass action and it has changed the Custom Field in the back end, but for some reason the live product in the front end still shows the old content.
Can you think of a reason why and a solution if possible?
11 years 6 months ago #196484
Replied by nicolas on topic "Custom Fields" don't update on live products
If you value of the custom field was changed in the products of the backend but not on the frontend, then the logical reason is that you have some caching on your website that you should clear in order to see the new data of the products.
Time to create page: 0.185 seconds
