- Thank you received: 1
jquery-ui.js loaded in products page
11 years 5 months ago #199268
by babaei
jquery-ui.js loaded in products page was created by babaei
instrucenter.com/fa/hydraulic/hydraulic-...pressure-vppl-022pc5
-- Joomla version -- : 2.5.28
Hello
I noticed that a big js file loaded in my products page.
It is jquery-ui.js and is around 223kb.
As I noticed the author is hikashop.com
I want to know what this file is for and how I can disable loading this file.
BaBaEi
Hello
BaBaEi
11 years 5 months ago #199285
Replied by nicolas on topic jquery-ui.js loaded in products page
This file is an extension to the jquery library in order to display advanced graphical interfaces.
If you want to remove it, you can remove the line:
$doc->addScript(HIKASHOP_JS.'jquery-ui.min.js');
from the file administrator/components/com_hikashop/helpers/helper.php
This can potentially break some piece of the interface of HikaShop, so I don't recommend doing that change.
11 years 5 months ago #199965
by babaei
Replied by babaei on topic jquery-ui.js loaded in products page
hello and thanks for your guide
I removed the code and faced problem with cursor filters.
may i have a small js file for essential performance like cursor?
11 years 5 months ago #199971
by Jerome
Replied by Jerome on topic jquery-ui.js loaded in products page
The cursors require jquery-ui to work correctly so I recommend you to restore jquery-ui if you want to use filter cursors ; or not use the cursors.
Time to create page: 0.151 seconds
