Products in cart
11 years 4 months ago #201485 by phickman
Products in cart was created by phickman
-- Joomla version -- : 3.4.1
I have instances where a customer will order duplicates of one product. Currently when the second of the product is picked the cart will update the existing line item for that product. Say if they order 3 products, item #1 is Product A, item #2, is Product B, Item #3 is Product A again. Currently the cart will update the quantity value for product #1, when product #3 is added to the cart. So instead of 3 items in the cart, there will be 2.
Is it possible, in that instance for product #3 to create it's own line item, instead of updating the value in product #1?
Thanks!
11 years 4 months ago #201525 by Jerome
Replied by Jerome on topic Products in cart
There is no option to do that and if you want to have such kind of feature, it will require some modification in the HikaShop core.
The only moment when two identical products can be added into the cart in two different line is when you're using "item custom field" and the values of the custom fields are different.
11 years 4 months ago #201595 by phickman
Replied by phickman on topic Products in cart
Thanks for the suggestion Jerome. I might be able to get that to work.
Time to create page: 0.192 seconds
