Problem with Styles pack onsite
11 years 4 months ago #201778
by vanway
Problem with Styles pack onsite was created by vanway
-- HikaShop version -- : HikaShop Business: 2.4.0
-- Joomla version -- : 3.4.1.
Hi. I just bought the style pack and install it, and I'm having loads of troubles with it. I think it may have some incompetences with my template, which is strange since it says that hikashop styles goes over template styles... I 'm attaching an example here. The line in the cart module, has a strange style (all black) in the line that shows what is quantity, price, etc. I attach a file of my template with the pink style on, with that line circled in yellow, and a photo of the example of how your style should look according to your page.
There's more examples of these fails, but I'll wait since there might be a global solution?
Thank you
Thank you
- Thank you received: 1778
11 years 4 months ago #201863
by Mohamed Thelji
Replied by Mohamed Thelji on topic Problem with Styles pack onsite
To fix it you'll just have to use some CSS code and change the background of the cart tab header : www.hikashop.com/support/documentation/1...the-display.html#css
11 years 4 months ago #202065
by vanway
Replied by vanway on topic Problem with Styles pack onsite
Thank you Mohamed, I could change that. Now a bigger problem. On the product / show_quantity module, it has a lot of problems. As you can see in the picture below, the square where you can put the quantity overlaps de +/- button, and also, the "+" of the "+ add product" overlaps itself... I've tried to find out how to solve this, but I 'm not capable of... The code of the module is as follows:
Where could I fix this? I can't find how to solve it. Thank you.
<?php
* @version 2.4.0
* @author hikashop.com
* @copyright (C) 2010-2015 HIKARI SOFTWARE. All rights reserved.
* @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html
?><?php
$i =$this->params->get('i');
$min_quantity =$this->params->get('min_quantity');
$max_quantity =$this->params->get('max_quantity');
$html =$this->params->get('html');
$qLayout = JRequest::getVar('quantitylayout','show_default');
switch($qLayout){
case 'show_regrouped':
<div class="input-append hikashop_product_quantity_div hikashop_product_quantity_input_div_regrouped">
<input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" />
<div class="add-on hikashop_product_quantity_div hikashop_product_quantity_change_div_regrouped">
<div class="hikashop_product_quantity_change_div_plus_regrouped">
<a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a>
</div>
<a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">–</a>
</div>
</div>
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_regrouped">
<?php echo $html; ?>
</div>
<?php
break;
case 'show_select':
if($min_quantity == 0)
$min_quantity = 1;
if($max_quantity == 0)
$max_quantity = (int)$min_quantity * 15;
<div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_select">
<select id="hikashop_product_quantity_select_<?php echo $i; ?>" onchange="var id = this.id.replace('select','field'); document.getElementById(id).value = this.value;">
<?php
for($j = $min_quantity; $j <= $max_quantity; $j += $min_quantity){
echo '<option value="'.$j.'">'.$j.'</option>';
</select>
<input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="hidden" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" />
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_select">
</div>
<?php
break;
case 'show_simple':
<input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="hidden" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" />
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_simple">
</div>
<?php
break;
case 'show_leftright':
<div class="input-prepend input-append hikashop_product_quantity_div hikashop_product_quantity_change_div_leftright">
<span class="add-on">
</span>
</span>
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_leftright">
</div>
<?php
break;
case 'show_simplified':
<div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_simplified">
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_simplified">
</div>
<?php
break;
case 'show_default_div':
<div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_default">
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_change_div_default">
<div class="hikashop_product_quantity_change_div_plus_default">
</div>
<div class="hikashop_product_quantity_change_div_minus_default">
</div>
</div>
<div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_default">
</div>
<?php
break;
case 'show_default':
<table>
<tr>
<td rowspan="2">
</td>
<td>
</td>
<td rowspan="2">
</td>
</tr>
<tr>
<td>
</td>
</tr>
</table>
<?php
break;
default:
if(substr($qLayout,0,14) == 'show_quantity_'){
$doc = JFactory::getDocument();
$quantityDisplayType = hikashop_get('type.quantitydisplay');
if($quantityDisplayType->check( $qLayout, $app->getTemplate())){
$controller = new hikashopBridgeController(array('name'=>'product'));
$viewType = $doc->getType();
if(!HIKASHOP_PHP5) {
$view = & $controller->getView( '', $viewType, '');
} else {
$view = $controller->getView( '', $viewType, '');
$view->setLayout($qLayout);
echo $view->loadTemplate();
break;
</div>
</div>
</div>
</div>
</div>
<?php
break;
11 years 4 months ago #202079
by vanway
already solved it!
For those having the same trouble, you have to change the fields "Layout on product page" and "Quantity layout on product page" in the product edit page, and not in the main fields.
Thank you anyway!
Thank you anyway!
Time to create page: 0.193 seconds
