display many modules of products
11 years 4 months ago #201961
by ilemaitre
display many modules of products was created by ilemaitre
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.5.12
I'm trying to display 5 modules in 3 positions. I attached the positions I have. In each modules I display products from different categories from hikashop.
so the code must have the architecture in pic1, but instead of that the architecture is like in pic2.
the template with these positions work very well but not with hikashop content.
I work in localhost so i cant provide you my website.
So if you can help me with any idea it will be appreciated.
thank you
thank you
11 years 4 months ago #202013
Replied by nicolas on topic display many modules of products
I'm sorry but I don't understand the architecture images you attached.
Could you provide some screenshots of what you have with the different areas circled on the page so that we might better understand the issue ?
11 years 4 months ago #202020
by ilemaitre
Replied by ilemaitre on topic display many modules of products
I attached you 2 pics. the first what I wish to display with the code and the second what I have now.
as I said before it works fine but not with hikashop contents.
thank you.
thank you.
11 years 4 months ago #202034
Looking at the HTML in your screenshots, it looks like the products listing module display has been customized on your website (either by you or your template provider) and that there is an extra closing div tag </div> displayed by the module, which breaks the design of the positions of the template.
Rename the folder templates/YOUR_TEMPLATE/html/com_hikashop/product and that will disable all the view overrides of the products listings and that should hopefully remove the issue. And in that case, you want to contact either the person who did that customization for you, or your template provider for help. Otherwise, we would need to analyze the HTML and CSS of the page and maybe look at your view overrides and HikShop settings on your website backend in order to understand what's going on, which means that it would require that your website be accessible online so that we could access it.
Time to create page: 0.165 seconds
