Question about Variants & Main Products
11 years 3 months ago #206958
by ninjab
Question about Variants & Main Products was created by ninjab
-- Joomla version -- : 3.0
Hi there,
I am having a problem understanding how to set things up properly with products.
I have Product 1 which I have created variants for. And it goes like this:
Product 1 - Model XX-XXX (size 1)
Variant 2 - Model XX-YYY (size 2)
Variant 3 - Model XX-ZZZ (size 3)
When I am in category view I need to be able to choose size 1, size 2 and size 3. So I create a copy of Product 1 and it wont let me add the same variants as the model numbers are the same as Product 1 and its variants. Each size has its own order code and model number so it looks like there is no way to do this?
Because in category view I need to have the sizes selectable becuse they are sleeves for different devices but have the same name, but only are called Sleeve Macbook, Sleeve iPad and so on etc. So when the user clicks on the product, the variant's default needs to be model/product of the sleeve they chose, otherwise it is too confusing for them since they willl see a different price.
Is there a way to do this or am I only able to be able to create a product listing per size? If so its going to be quite tedious and long to setup.
Many thanks!
Hi there,
Many thanks!
11 years 3 months ago #206999
by Jerome
Replied by Jerome on topic Question about Variants & Main Products
If you have variants, you do not have the possibility to sell the main product, only his variants.
So you have to create a variant for the "size 1".
It is currently not possible to chose the characteristics in a product listing ; but it is possible to select item custom fields (which are provided by HikaShop business).
The reason that the characteristics are not available in a product listing is the amount of data that HikaShop should have to process/load in a listing.
Using item custom field will allow you to select a size but you will have just one single product in the database.
So you couldn't have different price per size, or different stock.
11 years 3 months ago #207027
by ninjab
Replied by ninjab on topic Question about Variants & Main Products
Hi Jerome
Thanks for the reply.
So basically what you are saying is that in order for me to accomplish what I am trying to do is that I can only do it if I have to create those SKUs separately? And the only variants can be is from colours only then.
11 years 3 months ago #207040
by Xavier
Replied by Xavier on topic Question about Variants & Main Products
Yes to have a listing with all the different sizes selectable, you will have to create one product per size, then for the colours you can use the custom item fields, this way the colours will be selectable in the listing too, no need to reach the product detail page.
Time to create page: 0.155 seconds
