Can't click on thumbnail for width < 1200 px
11 years 3 months ago #207336 by FilipHradil
-- HikaShop version -- : 2.50
I just discovered a weird bug on my website.
I can't clik on thumbnail when is device's width lower than 1200px.
I can't also click on breadcrubs on product page (for every resolution).
I've tried to overwrite view show.php with original file but it solved only problem with breadcrumbs.
Have you any ideas please?
Thank you
Filip
11 years 3 months ago #207338 by nicolas
1. The issue comes from your Joomla template.
If you remove the code:
float: none;
from the CSS:
#hikashop_product_right_part {width: 100%;float: none;margin: 0;}
in the file /templates/passage/css/style.css
it will work properly.
2. That's also a problem with your template CSS.
Add such CSS in that same file and it will fix the problem:
.prev-next {
width: 50% !important;
float: right !important;
position: relative !important;
I would recommend that you contact your template provider.
11 years 3 months ago #207386 by FilipHradil
thank you very much! :)
It solved my problem.
This problem came from my css modifications.
Filip
Time to create page: 0.182 seconds
