- Thank you received: 13
Minimum product Quantity per order, multiply by 3
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4
Hello!
Thank you so far for the excellent support!
My products have minimum Quantity per order : 1.
What i need to do, is for some products, the minimum Quantity per order to be 3, and when a logged in customer wants to order more than 3, i want that number to multiply by 3, and not by 1.
For example, when the customer clicks the + button, the number should add 3. so it would be:
minimun Quantity per order: 3, 6, 9 etc
Is that somehow possible?
Thank you
- Thank you received: 1778
A solution can be to :
- Sell products per unit for none logged users
- Sell products per pack of 3 products for logged in users
Note that you can restrict the displaying of your product regarding the user group by using Access level through your product configuration page.
Only logged users can see the prices and make orders, i ve done that part.
What i dont know how to do, is for some products, the amount of the order to multiply by 3, so when a user clicks the plus(+) button to add more products to his/her cart, the order number should go up from 3 to 6, from 6 to 9 etc...
Is it possible?
You can potentially use the "Show select" value for the option "Quantity input method" in Configuration > Display > Product or directly in the product or category edition page.
Then on the product edition page, set the minimum quantity per order to 3 and the select will automatically display multiple of 3 values.
If you really want an input field with a plus and minus buttons, you can create a new view with a name starting by "show_quantity_" and add the desired php/html code.
thank you for the answer, i checked what you said about "Show select" value for the option "Quantity input method" and yes it works.
Unfortunately my client wants the input field but i m going to need your help creating a new view as you said.
Could you write the code that is needed here?
Thank you
An easiest solution could be to select a value for the option "input quantity mehtod" and then edit the view "product / show_quantity" and customize the code of the selected quantity input method in order to have a specific increment, so this way no need to create a new view.
Xavier wrote: Hi,
Hello I am very interested this solution because I'm having the same problem.
My product has a maximum and a minimum number of orders, but mostly a minimum.
Capture 1 -> Capture 2
Please can you give me a clue how to get it? thanks.
But as I can get the user can not choose less than 2 and a maximum of 20 "exemple"?
It seems to work in part. capture
1. When we select a value below the minimum, the layer disappears payment.
2. The product becomes free. 1 product = free continuing purchase.
What am I doing wrong?
What you are looking for is the option "Quantity per order" in the part "restrictions and dimensions" of the product edition page.
There you can set a minimum and a maximum quantity to order.
What you were filling is a price based on a quantity, so with your settings the price where applied only if the customer add 2 products or more to the cart. So when trying to add 1 product, no prices set.
