Characteristic order reversed when product is copi
11 years 1 week ago #215674
by Kingwell
Characteristic order reversed when product is copi was created by Kingwell
-- Joomla version -- : 3.4.0
-- PHP version -- : 5.3.28
Hikashop: 2.6.0
Joomla 3.4.0
PHP 5.3.28
When i copy a product with 256 variants (Colour, Size, Type) the order of how the characteristics are displayed gets reversed.
In the original product it is ordered by Colour -> Size -> Type,
When the product is copied the new product shows Type -> Size -> Colour
Is there a way i can correct this without deleting the variants and starting again?
Thanks!
Oli
Hikashop: 2.6.0
Joomla 3.4.0
PHP 5.3.28
Thanks!
Oli
11 years 1 week ago #215675
by Jerome
Replied by Jerome on topic Characteristic order reversed when product is copi
In HikaShop 2.6.0 you should be able to change the sort of the characteristic when editing the product.
The different lines can be moved using drag'n'drop.
The following user(s) said Thank You: Kingwell
11 years 6 days ago #215788
by Kingwell
Replied by Kingwell on topic Characteristic order reversed when product is copi
Thanks for this!
turned out a few files had failed to install on the update to 2.6, reinstall fixed it!
Time to create page: 0.175 seconds
