- Thank you received: 2
Serach product problems
11 years 6 days ago #215794
by LAMF
Serach product problems was created by LAMF
www.dsgbutiken.com/index.php/webshop
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.5.28
I have a simple question.
I have added a search field and a button to be pressed after search string is entered in teh search field.
After that I get a list of all items that match the serach phrase, for example "Lamp" generates all lamps in the shop.
Now when clilcking one of those links it points to a non existing URL with a correct URL + /component/search/ in the end and this is making an error 404 Page not found.
So how can I get rid of the /component/search/ at the end of all URLs?
I have compared it to another site I have witrh HikaShop Business that works but can't find any oddities between them.
I would bve very happy if you solved this for me.
Best regards,
Micke
Best regards,
Micke
11 years 6 days ago #215801
Replied by nicolas on topic Serach product problems
That issue has already been fixed. Update to HikaShop 2.6.0 and that should be ok.
The following user(s) said Thank You: LAMF
11 years 5 days ago #215871
by LAMF
Replied by LAMF on topic Serach product problems
Thanks that did it!
Time to create page: 0.200 seconds
