Product options not responsive
11 years 1 day ago #216300 by madjedo
-- Joomla version -- : 3.4
I added a product option to one of my products.
Everything went smoothly but when entering the product page from a mobile (Iphone 5) it doesn't look very good.
I have attached a picture where I explain it better.
Best Regards,
11 years 1 day ago #216311 by nicolas
It should be easy to customize with a bit of CSS code.
Please provide a link to that page so that we can see the problem if you want us to give the exact CSS to use.
11 years 20 hours ago #216423 by madjedo
11 years 18 hours ago #216441 by madjedo
Hey, I just turned on vote & comments for products and I have the same issue.
Where the user enters his username. See attached image.
11 years 6 hours ago - 11 years 16 hours ago #216450 by Philip
I will show you step by step how to custom your CSS, That will solve your trouble.
Take care to follow precisely ALL steps.
1° Go to the Components -> HikaShop -> Configuration
2° Click on "Display" tab
3° Click on CSS
4° Here, on Front-end CSS File you must have selected "custom" BUT if not, select it!
5° Click on the little pen/ "edit" icon
6° Copy & Paste this code :
/* ADD CSS CODE HERE !!! */
@media only screen and (max-width:400px) {
select #hikashop_product_option_0 {
width: 100%;
/* CUSTOM END */
AND don't forget to save !!!
If I'm right your issue will be solve with this.
Last edit: 11 years 16 hours ago by Philip.
The following user(s) said Thank You: madjedo
10 years 11 months ago - 10 years 11 months ago #216877 by madjedo
Hi, I am sorry but it didn't work...
*just took care of it, changed the code to:
.hikashop_product_options_table select{padding:2px; color:#666; width:100%}
/* CUSTOM END */
Last edit: 10 years 11 months ago by madjedo.
Time to create page: 0.173 seconds
