CDN unavailable leads to product display issue
10 years 11 months ago #216861
by withram
CDN unavailable leads to product display issue was created by withram
-- Browser(s) name and version -- : any browser
-- Error-message(debug-mod must be tuned on) -- : Failed to load resource: net::ERR_CONNECTION_TIMED_OUT at hikashop.com/cdn/shadowbox/shadowbox.css
Failed to load resource: net::ERR_CONNECTION_TIMED_OUT at hikashop.com/cdn/shadowbox/shadowbox.js
Uncaught ReferenceError: Shadowbox is not defined
Hello! Today url hikashop.com was unavailable and we could't open the product page due to those errors above. Give us an advice please, what to do to avoid this in future.
10 years 11 months ago #216863
by Jerome
Replied by Jerome on topic CDN unavailable leads to product display issue
Best is to install shadowbox directly in your website (using a plugin or by including it in your template).
Then you can not use "shadowbox (external)" for the image popup system.
www.hikashop.com/support/support/documen...html#display_general
10 years 11 months ago #216904
by withram
Replied by withram on topic CDN unavailable leads to product display issue
Where can I find such a plugin? How to configure General Display options?
10 years 11 months ago #216908
Replied by nicolas on topic CDN unavailable leads to product display issue
There are many plugins and ways to install shadowbox on a joomla website.
Here are the first results if you search on google:
www.youtube.com/watch?v=7KkbcHd8n94
extensions.joomla.org/extension/shadowbox-media-viewer
www.joomlalondon.co.uk/extensions/shadowbox-plugin
Once you have shadowbox installed on your Joomla, just change the "Image popup mode" setting of the HikaShop configuration from "shadowbox (external)" to "shadowbox (embedded)" and your image popups for your products should still work but won't rely on our CDN.
10 years 11 months ago #217015
by withram
Thank you, I will try.
Time to create page: 0.206 seconds
