Image and description box size problem
11 years 1 month ago #217034 by fgonc124
-- url of the page with the problem -- : www.lojadocaopreto.com
-- Joomla version -- : 2.5
-- Browser(s) name and version -- : Chrome 45.0.2454.101
I upgraded Hikashop on my Joomla 2.5 site to Hikashop 2.6.0
After that, all product pages have problem with box size . It looks like all boxes are resized to largest product box on that page.
If there is one product wtih a large description then all products occupy the same space on that page.
thank you for your help
11 years 1 month ago #217036 by Jerome
In HikaShop 2.6.0 we added a "height consistency" script for the product and category listings.
In the view "product / listing_div", you will find the line
<div class="hikashop_products" data-consistencyheight=".hikashop_subcontainer">
If you remove the data-consistencyheight parameter, the script won't be process anymore and each product container will have his own size.
The following user(s) said Thank You: Chrisomio
11 years 1 month ago #217782 by simmiepam
My problem is not how they display to the user...but how it displays in my backend.
I cannot see the entire window for the description to type...some of it is hidden behind another box.
Are you saying that I have to change some code in order to see this box in it's entirety to include my content?
Pam
11 years 1 month ago #217831 by nicolas
The issue is that your editor has toolbars bigger than the area where we display the editor (which isn't the case with the default editor of Joomla).
Either shorten the toolbars of your editor, or change the "editor" setting of your HikaShop configuration in order to use the standard tinyMCE editor and you shouldn't have the problem anymore.
