- Thank you received: 4
insert product in article don't show right
10 years 11 months ago #217312
by Cattelan
insert product in article don't show right was created by Cattelan
www.ilmondodiwit.com
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.6.14-1+deb.sury.org~trusty+1
-- Browser(s) name and version -- : opera-firefox-chrome
Hallo.
When i insert an product in joomla article it shows up the wrong article and does not respect the options i give.
Example:
i want to insert this product
which should be this
www.ilmondodiwit.com/shop/artigianali/75...chio-della-vita.html
instead it shows up like the first article in the blog listing here: www.ilmondodiwit.com/notizie/ultime/
check the same article clicking in the title and it shows up right?????? www.ilmondodiwit.com/20151014339/ultime/...chio-della-vita.html
I have caching disabled in my joomla config and i tried in different browsers also cleaning complete history.
The result is always wrong.
How can i fix this
thanks for you reply
This is blog view which is showing wrong
This is article view which is showing right - same article !!!
Hallo.
Example:
How can i fix this
10 years 11 months ago #217331
Replied by nicolas on topic insert product in article don't show right
Wouldn't the problem come from the "canonical URL" of the product being wrong in the settings of the product ? If you have it filled, try emptying that field.
Time to create page: 0.182 seconds
