Cart Module settings have no effect
10 years 11 months ago #218099 by Kingwell
-- Joomla version -- : 3.4.0
-- PHP version -- : 5.3.28
Hi there,
When trying to set up my cart to display in my T3/purityIII off canvas sidebar, the cart display overflows slightly( see screenshot).
My problem is when i try to edit the cart module (mod_hikashop_cart), none of the settings have any visual effect on the module displayed, for instance i have tried hiding the quantity selector, hiding the price, showing price only including tax not both, and no matter what i do, nothing changes.
The only thing that does change when i edit the module, is the module name, which when changed, updates on the sidebar too.
Caching is disabled on joomla, as well as cache being cleared on browser etc
Am i missing something here? any help would be appreciated.
Oli
10 years 11 months ago #218102 by nicolas
Thank you for your feedback. That has been fixed. Please download again the latest version install package on our website and install it on yours and that should add the patch for that problem.
10 years 11 months ago - 10 years 11 months ago #218466 by Kingwell
Thanks for that, Could you tell me if there is a zip available with the files in the same folder hierarchy as they are deployed on the webserver?
I've had to make numerous modifications to our version of hikashop to achieve the layout we desire, and as such i cannot simply update the files as it overwrites all of our code changes.
At the moment i have to dismantle the installer and place it manually into the correct hierarchy so that i can compare changes and update the files where necessary.
Thanks, Oli
Last edit: 10 years 11 months ago by Kingwell.
10 years 11 months ago - 10 years 11 months ago #218469 by Xavier
The modifications have been done in the cart module.
So I don't think you made changes on these files directly, here is the latest version of that module:
Just for information, when you say that you done numerous modifications, where have you done it ?
On views via an override ? If it is, so you can update HikaShop and you will not loose any changes.
Last edit: 10 years 11 months ago by Xavier.
Time to create page: 0.182 seconds
