- Thank you received: 1
Custom ordering of products?
- NanoPlanet
10 years 11 months ago #218733
by NanoPlanet
Custom ordering of products? was created by NanoPlanet
-- Joomla version -- : 3.4.5
Is there a way to customize the order in which products display in a given category? Currently the only options are ascending or descending and my client really wants to be able to re-organize the order on the back end and have it reflect on the front end.
Many thanks!
Many thanks!
10 years 11 months ago #218742
by Xavier
Replied by Xavier on topic Custom ordering of products?
In the menu / module settings, you can select another value for the option "ordering_field".
This allow you to filter in the order set in the backend if you select the value "Ordering".
- NanoPlanet
10 years 11 months ago #218862
by NanoPlanet
This sounds promising. Where are the Menu / Module settings?
Replied by NanoPlanet on topic Custom ordering of products?
Xavier wrote: Hi,
- NanoPlanet
10 years 11 months ago #218867
by NanoPlanet
Nevermind - I figured it out
Thank you!
Time to create page: 0.176 seconds
