Sort by product code
10 years 10 months ago - 10 years 10 months ago #221649 by Squashtoppertje
-- HikaShop version -- : 2.6.0. Business
I have set a menu to show the products and sort them by product_code. However this results in sorting like:
1
100
1000
1001
105
106
2
Where I would like it to sort numeric like:
1
2
100
105
106
1000
1001
How can I change this?
Thanks!
Last edit: 10 years 10 months ago by Squashtoppertje.
10 years 10 months ago #221655 by nicolas
Replied by nicolas on topic Sort by product code
As the product_code is a text field, the sorting is done alphabetically, character by character and thus 100 comes before 2.
Either add trailing zeros so that all the product_codes have the same number of characters, or change the product_code column type to integer in the hikashop_product table of your database via your phpmyadmin and that will do what you want.
The following user(s) said Thank You: Squashtoppertje
10 years 10 months ago #221813 by Squashtoppertje
Well, changing it to "integer" seemed the easiest solution, but this wasn't the case. I found out that if you duplicate a product the product_code gets some text attached, xxx-copyxxx. Because this field is an integer now, the data can not be stored, which results in removal of both products! Auch... :(
Is there a way to get around this?
(If I use trailing zero's then I need to remove all products before importing, because the poduct_code is needed to match the import with the product. I'd rather not delete all products).
10 years 10 months ago #221825 by nicolas
You can change the line:
$newProduct->product_code = $this->template->product_code.'_copy'.rand();
$newProduct->product_code = $this->template->product_code.rand();
in the file administrator/components/com_hikashop/helpers/import.php and that will allow you to copy the products even if the product_code is an integer.
Time to create page: 0.231 seconds
