Product display not correct in initial display
10 years 10 months ago #222149 by bmm01
-- url of the page with the problem -- : midwestmeats.com.au/online-butcher/category/52-christmas-hamper
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.5.30
-- Browser(s) name and version -- : Firefox 42.0
This is a really weird issue. I updated the site midwestmeats.com.au to Joomla 3.4.5 and Hikashop 2.6.0 after testing in the dev environment where everything was OK.
When you display a Hikashop product listing the display is not correct (Add to Cart buttons obscured as shown). When you refresh that page it's ok. Could it be something to do with the image sizes not being uniform?
I have cleared my browser caches and flushed the Joomla and Site Ground caches but no effect.
Any hints greatly appreciated
10 years 10 months ago #222155 by Xavier
Please try to edit the view "product / listing_div" and remove that code:
data-consistencyheight=".hikashop_subcontainer"
This code allow to set the same height for all the elements on the page, but if there is view editions, so it can potentially broke the display.
The following user(s) said Thank You: bmm01
10 years 10 months ago #222265 by bmm01
Thanks Xavier
That worked and fixed the problem!
Time to create page: 0.176 seconds
