- Thank you received: 3
Problem creating Characteristics
10 years 9 months ago #223923
by picht
Problem creating Characteristics was created by picht
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.6.16
I do the following:
Picht
I do the following:
- Click new on the Characteristics page (to create a new one)
- Fill out the name of the characteristic
- Add 3 new values
- Delete 2 of the values
- Save and close the newly ceated characteristic
Picht
10 years 9 months ago #224024
Replied by nicolas on topic Problem creating Characteristics
Can you try to delete again the two values ? Does that help ?
On which list of characteristics you see the values ?
10 years 9 months ago #224510
by picht
Replied by picht on topic Problem creating Characteristics
Deleting the values is fine. But it still is a bug that they appear on the characteristics list.
I see it on the list from Dashboard -> Products -> Characteristics
10 years 9 months ago #224567
So that means that they would have been added as normal characteristics, not values of characteristics.
And if you delete them in the listing of characteristics, it's ok then ?
10 years 9 months ago #224595
by picht
Have you tried to do as described in my first post ?
They are added as values and then deleted again and then they end up as characteristics. It is very strange.
/Picht
/Picht
10 years 9 months ago #224598
by Jerome
Replied by Jerome on topic Problem creating Characteristics
Thanks for the report. I already reported that issue 13 months ago.
It will be fixed when HikaShop will integrate the characteristic edition system from HikaMarket.
Time to create page: 0.173 seconds
