- Thank you received: 1
Different page layout per product
10 years 9 months ago #225599
by xatzopou
Different page layout per product was created by xatzopou
185.25.22.156/petshop.gr/
-- Joomla version -- : 3.4.8
Hello and a Happy New Year.
On product's backend I see that there is the option to choose Page Layout one from the prebuilds Hikashop's layouts (Inherit, Default, Reversed, Tabular).
I already know how to override and customize them by my needs but I want to add a couple of new layouts e.g. MyLayout1, MyLayout2, etc so to easily select it from the product's backend.
10 years 9 months ago #225613
by lousyfool
Replied by lousyfool on topic Different page layout per product
You can create and use as many product page layouts as you want, just make sure the file names start with "show_". So, name them e.g. "show_mylayout1.php", "show_mylayout2.php". They will then be selectable in the dropdown.
The following user(s) said Thank You: xatzopou
10 years 9 months ago #225605
by Xavier
Replied by Xavier on topic Different page layout per product
So in HikaShop > Display > Views, edit a product display view, for example "show_default" and then you will see that you can rename it: take.ms/0h0RF
So just rename the view, and save it. That way it will create a new product display view, and you will be able to select it from the product edition page.
Time to create page: 0.232 seconds
