Donot show 'best rated' products on product page
10 years 8 months ago - 10 years 8 months ago #226285 by storeitonline
-- url of the page with the problem -- : www.1stopmotoronderdelen.nl
When selecting a product, the page also shows a list of 'best rated' products. This happened after moving my hikashop database to another server. I didn't have this issue in the old situation.
I can't recall that I changed any files manually in the old situation.
Checked my menu settings and they were alle the same.......
Really puzzled right now on where to disable the showing of 'best rated' products.
EDIT: Module 'best rated' is disabled
Last edit: 10 years 8 months ago by storeitonline.
10 years 8 months ago #226301 by storeitonline
Just found out that it is related to the module 'best rated'. (Turning off the title e.g. has exactly that effect !)
However, the module is 'unpublished'...... :\
10 years 8 months ago #226305 by storeitonline
I think we have a bug here.
Despite the fact that the module is not published, and I even assigned it to no menu, it is displayed !!
I now worked around it by assinging a module that does not contain any items......
10 years 8 months ago #226288 by Mohamed Thelji
You should probably check the option "Modules to display under the main area" via "Hikashop->System->Configuration->Display" and unset the 'Best rated' module.
10 years 8 months ago #226404 by storeitonline
Pffffffffff..................
so many options everywhere, that I missed that one. Thanks.
But I also cannot recall turning it on .... and all other modules to display are turned off as well..... so still strange that it was now on.
Anyway... Thanks for the tip....
Time to create page: 0.203 seconds
