Product Not Found
10 years 8 months ago - 10 years 8 months ago #226531 by ankitch
Product Not Found was created by ankitch
-- Joomla version -- : 2.5.6
-- PHP version -- : 2.6.1
-- Error-message(debug-mod must be tuned on) -- : Product Not Found
Url is test.safka.co.nz/
Click on some products under latest product it shows product not found page while the product exists, but when we off the SEF and Url rewriting then it works fine.Why? :( :( :(
Last edit: 10 years 8 months ago by ankitch.
10 years 8 months ago #226534 by Xavier
Replied by Xavier on topic Product Not Found
What are your settings regarding the canonical urls ? (configuration > features > SEF urls) If it is enable, then try to disable it.
If when disabled it is working fine, so you have to delete/edit all your canonical urls in the product edition pages or let the option disabled.
You should be able to find many other topics talking about canonical urls ;)
The following user(s) said Thank You: ankitch
10 years 8 months ago #226755 by ankitch
Replied by ankitch on topic Product Not Found
is there any other way xavier?? because we don't want to delete our canonical urls. Is it possible with them ???
10 years 8 months ago #226768 by nicolas
Replied by nicolas on topic Product Not Found
You can keep the canonical URLs. Just turn off the "force canonical URLs on listings" setting of the HikaShop configuration and the system won't use the canonical URLs on the listings but it will still be used as canonical URL.
Time to create page: 0.208 seconds
