Products quantities problem / product div problem
10 years 8 months ago #228550 by mr.mauscat
-- url of the page with the problem -- : www.namibiabooks.com/joomla/english-books/non-fiction
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.5.31
-- Browser(s) name and version -- : Firefrox 43.0.4
Hi.
I have 2 issus on the page:
1. In the bottom modules the number of products in a category are shown twice. Why?
2. For some of the products shown, the hikashop_subcontainer seems to be too large in height. Here it works well: www.namibiabooks.com/joomla/english-book...ory-politics-culture .
Here there is too much height: www.namibiabooks.com/joomla/deutsche-bue...grafien-erinnerungen
I understand that the several containers are rendered to have the same height, which is great. But I think there's too much white space (about 70 px) under the Add to Cart button. I just can't figure out why.
Kind regards,
Sebastian
10 years 8 months ago #228553 by Mohamed Thelji
Hello Sebastian,
You should check the value that you have set through the "Pane height" option through your product listing menu/module configuration pages. If you didn't set any value in it, note that you can also set a value for each product listing menu/module.
Note that another solution can be to directly use some CSS code : www.hikashop.com/support/support/documen...the-display.html#css
10 years 8 months ago #228656 by mr.mauscat
Okay - Let me see. What about my second issue;
Sebastian
10 years 8 months ago #228663 by nicolas
Edit the file "listing_list" of the view "category" via the menu Display>Views and replace its content by:
<?php if(empty($this->rows)) return; $pagination = $this->config->get('pagination','bottom'); if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value) { $this->pagination->form = '_top'; ?> <form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top"> <div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_top"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_('form.token'); ?> </form> <?php } ?> <div class="hikashop_subcategories"> <?php $app = JFactory::getApplication(); $in_hikashop_context = (JRequest::getString('option') == HIKASHOP_COMPONENT && in_array(JRequest::getString('ctrl','category'), array('category', 'product'))); $cid = 0; $last_category_selected = 0; if($in_hikashop_context) { if(JRequest::getString('ctrl','category') == 'product' && JRequest::getString('task','listing') == 'show') { $last_category_selected = (int)$app->getUserState(HIKASHOP_COMPONENT.'.last_category_selected', 0); $config =& hikashop_config(); $pathway_sef_name = $config->get('pathway_sef_name', 'category_pathway'); $cid = JRequest::getInt($pathway_sef_name, 0); } else { $cid = JRequest::getInt('cid', 0); } } $only_if_products = $this->params->get('only_if_products', 0); switch($this->params->get('child_display_type')){ case 'nochild': default: ?> <ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"> <?php $width = 0; if((int)$this->params->get('columns', 0) > 0) $width = (int)(100 / (int)$this->params->get('columns')); if(empty($width)) $width = ''; else $width = 'style="width:' . (int)$width . '%;"'; $found = 0; if($in_hikashop_context) { $found = $last_category_selected; foreach($this->rows as $row) { if($cid == $row->category_id) { $found = (int)$row->category_id; $app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', (int)$row->category_id); break; } } } foreach($this->rows as $row) { if($only_if_products && $row->number_of_products < 1) continue; $link = $this->getLink($row); $class = ($found == $row->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>" <?php echo $width; ?>> <a href="<?php echo $link; ?>"><?php echo $row->category_name; if($this->params->get('number_of_products', 0)) { echo ' (' . $row->number_of_products . ')'; } ?></a> </li> <?php } ?> </ul> <?php break; case 'allchildsexpand': if($this->params->get('ul_display_simplelist', 0)) { ?> <ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"> <?php foreach($this->rows as $k => $row) { if($only_if_products && $row->number_of_products < 1) continue; $found = 0; if($in_hikashop_context) { $found = $last_category_selected; if($cid == $row->category_id) { $found = (int)$row->category_id; $app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', (int)$row->category_id); } } $link = $this->getLink($row); $class = ($found == $row->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a href="<?php echo $link; ?>"><?php echo $row->category_name; if($this->params->get('number_of_products', 0)) echo ' (' . $row->number_of_products . ')'; ?></a> <?php // DISPLAY SUB CATEGORIES if(!empty($row->childs)) { $limit = $this->params->get('child_limit'); $i = 0; ?> <ul> <?php foreach($row->childs as $child) { if($only_if_products && $child->number_of_products < 1) continue; if(!empty($limit) && $i >= $limit) { break; } $i++; $link = $this->getLink($child); $class = ($found == $child->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a href="<?php echo $link; ?>"><?php echo $child->category_name; if($this->params->get('number_of_products', 0)) echo ' (' . $child->number_of_products . ')'; ?></a> </li> <?php } ?> </ul> <?php } ?> </li> <?php } ?> </ul> <?php } else { ?> <div id="category_panel_<?php echo $this->params->get('id');?>" class="pane-sliders"> <?php foreach($this->rows as $k => $row) { if($only_if_products && $row->number_of_products < 1) continue; if($this->params->get('number_of_products', 0)) { $row->category_name .= ' (' . $row->number_of_products . ')'; } if(!$this->module || $this->params->get('links_on_main_categories')){ $link = $this->getLink($row); $row->category_name = '<a href="' . $link . '">' . $row->category_name . '</a>'; } ?> <div class="panel"> <h4 class="jpane-toggler title" id="category_pane_<?php echo $k;?>" style="cursor:default;"> <span><?php echo $row->category_name; ?></span> </h4> <div class="jpane-slider content"> <ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"> <?php if(!empty($row->childs)) { $app = JFactory::getApplication(); $found = ''; if($in_hikashop_context) { foreach($row->childs as $child) { if($cid == $child->category_id) { $found = (int)$child->category_id; $app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', (int)$child->category_id); break; } } } $limit = $this->params->get('child_limit'); $i = 0; foreach($row->childs as $child) { if($only_if_products && $child->number_of_products < 1) continue; if(!empty($limit) && $i >= $limit) break; $i++; $link = $this->getLink($child); $class = ($found == $child->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a href="<?php echo $link; ?>"><?php echo $child->category_name; if($this->params->get('number_of_products', 0)) { echo ' (' . $child->number_of_products . ')'; } ?></a> </li> <?php } } else { echo JText::_('HIKA_LISTING_LIST_EMPTY'); } ?> </ul> </div> </div> <?php } ?> </div> <?php } break; case 'allchilds': $found = -1; $sub_selected = -1; if($in_hikashop_context) { if(JRequest::getString('ctrl', 'category') == 'product' && JRequest::getString('task', 'listing') == 'show' && empty($cid)) { $database = JFactory::getDBO(); $query = 'SELECT category_id FROM '.hikashop_table('product_category').' WHERE product_id = ' . (int)hikashop_getCID('product_id') . ' ORDER BY product_category_id ASC'; $database->setQuery($query); $cid = $database->loadResult(); if(empty($cid)) { $class = hikashop_get('class.product'); $product = $class->get(hikashop_getCID('product_id')); if($product && $product->product_type == 'variant' && $product->product_parent_id) { $query = 'SELECT category_id FROM '.hikashop_table('product_category').' WHERE product_id = ' . (int)$product->product_parent_id . ' ORDER BY product_category_id ASC'; $database->setQuery($query); $cid = $database->loadResult(); } } } $i = 0; foreach($this->rows as $k => $row) { if($only_if_products && $row->number_of_products < 1) continue; if((int)$row->category_id == $cid) { $found = $i; break; } if(!empty($row->childs)) { foreach($row->childs as $child) { if($child->category_id == $cid) { $found = $i; $sub_selected = $row->category_id; break 2; } } } $i++; } $app = JFactory::getApplication(); if($found >= 0) { $app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', $found); } elseif(JRequest::getString('ctrl', 'category') != 'category' || JRequest::getString('task','listing') != 'listing') { $found = (int)$last_category_selected; } } else { $cid = 0; } if($this->params->get('ul_display_simplelist', 0)) { ?> <ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"> <?php foreach($this->rows as $k => $row) { if($only_if_products && $row->number_of_products < 1) continue; $link = $this->getLink($row); $class = ($cid == $row->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a href="<?php echo $link; ?>"><?php echo $row->category_name; if($this->params->get('number_of_products', 0)) echo ' (' . $row->number_of_products . ')'; ?></a> <?php // DISPLAY SUB CATEGORIES if(!empty($row->childs)) { $sub_selected = false; if($cid != $row->category_id) { foreach($row->childs as $child) { if($cid == $child->category_id) { $sub_selected = true; break; } } } if($cid == $row->category_id || $sub_selected == $row->category_id) { $limit = $this->params->get('child_limit'); $i = 0; ?> <ul> <?php foreach($row->childs as $child) { if($only_if_products && $child->number_of_products < 1) continue; if(!empty($limit) && $i >= $limit) break; $i++; $link = $this->getLink($child); $class = ($found == $child->category_id) ? ' current active' : ''; ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a href="<?php echo $link; ?>"><?php echo $child->category_name; if($this->params->get('number_of_products', 0)) echo ' (' . $child->number_of_products . ')'; ?></a> </li> <?php } ?> </ul> <?php } } ?> </li> <?php } ?> </ul> <?php } else { jimport('joomla.html.pane'); $this->tabs = hikashop_get('helper.sliders'); $this->tabs->setOptions(array( 'startOffset' => $found, 'startTransition' => 0, 'displayFirst' => 0 )); echo $this->tabs->startPane('category_panel_'.$this->params->get('id')); foreach($this->rows as $k => $row) { if($only_if_products && $row->number_of_products < 1) continue; if($this->params->get('number_of_products', 0)) { $row->category_name .= ' (' . $row->number_of_products . ')'; } if( !$this->module || $this->params->get('links_on_main_categories') || empty($row->childs)) { $link = $this->getLink($row); $row->category_name = '<a href="'.$link.'">'.$row->category_name.'</a>'; } // Allow to open the slider of the currently displayed category $toOpen = false; // Get the category id for category listing $cid = hikashop_getCid(); // Get categories from product page if(JRequest::getVar('ctrl','category') == 'product' && JRequest::getVar('task','listing') == 'show'){ $productClass = hikashop_get('class.product'); $cid = $productClass->getCategories(hikashop_getCid()); } // Get main category from product listing if(!HIKASHOP_J30){ $menuClass = hikashop_get('class.menus'); $menuData = $menuClass->get($this->params->get('itemid',0)); if(@$menuData->hikashop_params['content_type']=='product' && isset($menuData->hikashop_params['selectparentlisting'])) $cid = $menuData->hikashop_params['selectparentlisting']; }else{ $app = JFactory::getApplication(); $menuItem = $app->getMenu()->getActive(); $hkParams = $menuItem->params->get('hk_product',false); if(isset($hkParams->category)) $cid = $hkParams->category; } if(!is_array($cid)) $cid = array($cid); if(in_array($row->category_id,$cid)) $toOpen = true; if(!empty($row->childs)) { foreach($row->childs as $child) { if(in_array($child->category_id,$cid)) $toOpen = true; } } echo $this->tabs->startPanel($row->category_name, 'category_pane_'.$k, !empty($row->childs), $toOpen); if(!empty($row->childs)) { ?> <ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"> <?php foreach($row->childs as $child) { if($only_if_products && $child->number_of_products < 1) continue; $class = ($cid == $child->category_id) ? ' current active' : ''; $link = $this->getLink($child); ?> <li class="hikashop_category_list_item<?php echo $class; ?>"> <a class="hikashop_category_list_item_link" href="<?php echo $link; ?>"><?php echo $child->category_name; if($this->params->get('number_of_products', 0)) echo ' (' . $child->number_of_products . ')'; ?></a> </li> <?php } ?> </ul> <?php } else { echo JText::_('HIKA_LISTING_LIST_EMPTY'); } echo $this->tabs->endPanel(); } echo $this->tabs->endPane(); } break; } ?> </div> <?php if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value) { $this->pagination->form = '_bottom'; ?> <form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom"> <div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_bottom"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_('form.token'); ?> </form> <?php }
That should fix the issue.
Time to create page: 0.228 seconds
