Product images not displaying on frontend
- girish.tiwaricb
10 years 7 months ago #230637
by girish.tiwaricb
Product images not displaying on frontend was created by girish.tiwaricb
-- HikaShop version -- : HikaShop Business 2.3.5
-- Joomla version -- : 3.4.8
-- PHP version -- : 5
-- Error-message(debug-mod must be tuned on) -- : $this->image->getThumbnail() not returning anything
We are not able to see product images on the frontend product listing, detail, category pages. But when I am checking the same product in admin panel then the image is showing correctly. I am sure this cannot be a file permission issue because the <img> tag src parameter is also showing blank.
I am assuming $this->image->getThumbnail() is not returning anything. Please advise asap.
10 years 7 months ago #230640
Replied by nicolas on topic Product images not displaying on frontend
If you look at the code in the view listing_img_title which is used for the listing of products by default you can see that:
So if the call to getThumbnail would return nothing, it wouldn't go in the if and the img tag wouldn't be displayed at all.
I've checked your website and I can see that the view was heavily modified:
take.ms/PfJap
And I actually don't see the img tag, just an a tag without any img tag inside (I suppose that there should be the img tag normally in there).
I would say that there is a high chance that it comes from the customizations in the view files.
If you rename the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ to something else via FTP, that will deactivate all the overrides for the products. If the images are then displayed properly, they it would confirm that it comes from the modifications of the code.
Otherwise, it might be an issue with the generation of the thumbnails (like not being able to store the thumbnails after their generation due to a permission issue in your upload folder or something similar).
$img = $this->image->getThumbnail(@$this->row->file_path, array('width' => $this->image->main_thumbnail_x, 'height' => $this->image->main_thumbnail_y), $image_options);
if($img->success) {
echo '<img class="hikashop_product_listing_image" title="'.$this->escape(@$this->row->file_description).'" alt="'.$this->escape(@$this->row->file_name).'" src="'.$img->url.'"/>';
take.ms/PfJap
- girish.tiwaricb
10 years 7 months ago #230808
by girish.tiwaricb
Replied by girish.tiwaricb on topic Product images not displaying on frontend
Thanks for your reply. Actually, there is also a component installed JMS Multisite and we also have a staging site. The same files are present in the staging site also and the staging site is working fine. No image issue is occuring on the staging site.
Is it possible to disable product image feature from admin panel? Maybe some settings causing the issue.
10 years 7 months ago #230835
There is no option to deactivate the images on the backend.
- girish.tiwaricb
10 years 7 months ago #231222
by girish.tiwaricb
We have tried to rename the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ to something else via FTP, but still the images aren't showing. Do you have any idea/suggestion how it is happening?
10 years 7 months ago #231230
by Jerome
Replied by Jerome on topic Product images not displaying on frontend
If you're using JMS ; I suggest you to update all your components in order to be sure to have latest updates/fixes.
Time to create page: 0.174 seconds
