Customization of the inserted products display
10 years 7 months ago #231056 by lensky
-- url of the page with the problem -- : www.uniontrade.info/
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.6.0
I've copied and modified the file
plugins/system/hikashopproductinsert/hikashopproductinsert_view.php
in my template to show also the sku of the product.
But I don't find the way to display the manufacturer name, only the manufacturer id ...
Sorry I suppose this is by my poor knowledge of php but if you can, help me please.
thank you so much
Elena
10 years 7 months ago - 10 years 7 months ago #231105 by Philip
I think you can display product SKU AND manufacturer, simply by activated some options.
Follow this steps :
- Components => HikaShop => Configuration
- Click on Display tab, and select "Default parameters for products"
- Look for Display product code (Sku code) AND Display the manufacturer, and switch them ''On".
Hope this will help you.
Last edit: 10 years 7 months ago by Philip.
10 years 7 months ago #231188 by lensky
hi philip
my configuration is already as you describe. this works good, but only on category pages, product pages etc.
but if I put products into k2 articles with the product tag plugin I don't have options for code and for manufacturer (img 2 and 3)
this is why I edited the file plugins/system/hikashopproductinsert/hikashopproductinsert_view.php
as described in your documentation at page
www.hikashop.com/support.html?id=137:hik...ugins-coupongen-form
10 years 7 months ago #231211 by nicolas
There is no setting to do that. you'll have to add custom code for the file plugins/system/hikashopproductinsert/hikashopproductinsert_view.php
You can use such code to display the brand:
<?php $manufacturerClass = hikashop_get('class.category'); $manufacturer = $manufacturerClass->get($product->product_manufacturer_id); echo $manufacturer->category_name; ?>
Time to create page: 0.183 seconds
