Problems
10 years 2 months ago #246245 by GJBruins
Problems was created by GJBruins
-- url of the page with the problem -- : www.eco-pelletkachels.nl/
-- Joomla version -- : 3.6.0
-- PHP version -- : 5.6.22
Hey,
I have some problems with HikaShop on my website. Maybe one of you can help me. ( www.eco-pelletkachels.nl )
1. For one reason or another I manage to change the page order. I like the picture at the top and on the left, and the price at the bottom.
2. The small pictures below the large picture does not work for some reason.
( www.eco-pelletkachels.nl/index.php/onze-...el-nordic-fire-stylo )
3. I would like the tumbnails have a shadow and if you go over it that the shadow disappears. How and where could I change that?
10 years 2 months ago #246252 by nicolas
Replied by nicolas on topic Problems
1. It must come from the "layout on product page" setting of the HikaShop configuration that you set to "reversed" instead of "default" in the HikaShop configuration.
2. Does it work with the default layout ? Does it work with the default template of Joomla ?
Did you modify some code of some views of HikaShop for the product page via the menu Display>Views ?
3. You'll have to add custom code in the file "show_block_img" via the menu Display>Views. The code is not just one or two lines. It will require a developer to work on that for a bit.
10 years 2 months ago - 10 years 2 months ago #246504 by GJBruins
Replied by GJBruins on topic Problems
1. Oke i did change the configuration to default again. But now i want to change the layout. The price is now on the right next to the picture. Were do i change the layout?
I added some screendumps from my website.
Last edit: 10 years 2 months ago by GJBruins.
10 years 2 months ago #246522 by nicolas
You'll have to edit the file "show_default" via the menu Display>Views:
The following user(s) said Thank You: GJBruins
10 years 2 months ago #246911 by GJBruins
Oke thanks problem 1 is solved. thanks! Problem 2 was the badge logo wich was given trouble. It was over the thumbnails.
Time to create page: 0.182 seconds
