Hidden Variant Causing Issues
6 years 2 months ago #322507 by MyWorld
I'm in a bit of a pickle and I'm not sure how to fix it.
Say I have a Small, Medium and Large item.
If the Small is SOLD OUT, when the customer goes to the page, they see the SOLD OUT message without clicking on "Small". This is deceiving as it appears that all of that product is sold out. Please see the URL added in this post.
So what I usually do is create a default variant and add it as the first one, then use CSS to hide it to get rid of the issue stated above. See example attach.
If the user goes to the page and click "Add to Cart" without selecting a size, the DEFAULT variant is added to the cart.
How can I avoid getting the DEFAULT/(Hidden) variant added to the cart?
Thanks!
6 years 1 month ago #322542 by nicolas
What you could do is to edit the file product / show.php via the menu display>Views and add a bit of code at the beginning to hide the add to cart button when the page is loaded:
<script> window.hikashop.ready( function(){ document.querySelector('#hikashop_product_quantity_main .hikacart').style.display = 'none'; }); </script>
6 years 1 month ago - 6 years 1 month ago #322559 by MyWorld
Hi nicolas,
So the code works perfectly for products that have variants but it does not work for products that do not have variants.
If you look at products in the "Preowned" section you will notice that the "Add to Cart" button is not showing because there is only one of each so I didn't have to use variants.
So maybe the code should be;
If there is variant hide the "Add to Cart" button until a selection is made, if no variant then don't hide it.
I will send the URL privately so you can see what I mean.
Thanks!
Last edit: 6 years 1 month ago by MyWorld.
6 years 1 month ago #322561 by nicolas
Then you just need an additional check around that code:
<?php if(!empty($this->element->variants)) { ?> <script> window.hikashop.ready( function(){ document.querySelector('#hikashop_product_quantity_main .hikacart').style.display = 'none'; }); </script> <?php } ?>
6 years 1 month ago #322722 by MyWorld
Hi nicolas,
The website owner was saying that when the button is not visible customers may think that the product is out of stock. So she was asking if:
1) It's possible to disable the "add to cart" button and only enable it after they click on a size. Similar to what is done here:
www.roots.com/ca/en/cabin-slim-cuff-swea...emsourse=productlist
OR
2) Keep the button enabled/visible but display a message if they click on "add to cart" without selecting a size. Similar to what is done here:
www.gapcanada.ca/browse/product.do?pid=5...3_1#pdp-page-content
Thanks!
6 years 1 month ago #322733 by nicolas
Both are possible with some more complex custom coding.
If you want us to work on this for you, you can use our contact form to request a quote:
6 years 1 month ago - 6 years 1 month ago #322768 by MyWorld
Well I'm not sure what the cost will be..but I'm assuming it's not going to be cheap.
I think the option to have customers select a variant in order to add an item to the cart should be part of Hikashop software without having to pay extra to have it added as it's not a unique customization, this should have been a default feature from the start - other ecommerce softwares has it as part of their software, and not an added feature, eg: j2store.net/demo/index.php/shop/simple
I also had to purchase other extensions in order to improve Hikashop's functionality so having to pay for other extensions, pay for hikashop software, pay for a feature that I think should already be part of the software, sadly for me, I cannot afford at this time.
Thanks!
6 years 1 month ago #322784 by nicolas
the option to have customers select a variant in order to add an item to the cart should be part of Hikashop software without having to pay extra"
That is already the case by default.
By default, the default variant is preselected. And thus, it is impossible to add a product to the cart without having a variant selected.
You changed the way it works to make it look like a variant isn't preselected and thus created that problem with the add to cart button being visible even though it's not a working one.
So having us fix that issue, which is specific to your website has to be an extra.
Now if instead you want us to add the capability to not have a variant preselected, we actually added that capability with the latest version with the "Characteristics dynamic display" setting. However, this works only when the product has more than 1 characteristic. And that's why I proposed another solution to do what you want here:
www.hikashop.com/forum/feature-request/9...-variant.html#322632
This would be possible without any coding (just a bit of CSS).
So basically there is one choice:
- you follow my advice and you're done with a bit of CSS and product / variant configuration
- you do it your way and it requires a bit of javascript coding
- you stay with the default system available and wait for us to implement some improvement to the system in the future
I'm not here to try to get more money from you. I'm proposing solutions that you can have directly on your website, without having to wait for us to improve HikaShop in the future. I actually gave you some simple code propositions but it seems you want something more complex to code. At that point it requires proper development, and thus money for the time spent.
6 years 1 month ago #322815 by MyWorld
I definately was not implying that you were trying to get more money from me - I'm sorry if that's how it came across. I was just saying that I had no money at the moment for this. I thought this feature should have been something that is already part of the software. If you say it is, and I missed it - I apologize.
Thanks!
6 years 1 month ago #322824 by nicolas
No worries. But you didn't came back to me on this other thread where I provided a solution which should suit your needs:
Did you try it out ?
6 years 1 month ago #322844 by MyWorld
I will take a look and try it out. Thanks :)
6 years 1 month ago - 6 years 1 month ago #322882 by MyWorld
Hi nicolas,
After reading through your solution, although I prefer not to hide the "Add to Cart" button, I think I'll stick with the code that you provided for now and hopefully this improvement can be implemented to the system in the near future. It looks like, and I'm hoping, that with the code provided I don't have to add a HIDDEN default variant to the products anymore - that would save me some time :)
There seems to be some inconsistency with the products though, it works well with some products and not so well with others. I was trying to figure out why but I'm not seeing it.
I sent you a message with the URL of the products that works well and the ones that don't. Please let me know if there is something that I need to do differently when adding products or maybe the code needs some revisions.
Thanks I truly appreciate your help with this.
6 years 1 month ago - 6 years 1 month ago #322905 by Philip
Just a word to say that if you provide your 2 url link via Pm directly to Nicolas, he is actually on vacations, if you want to advance your subject without having to wait for his return, and in general to send us information use our Contact us form.
And don't forget to add an Url link to this topic in your message.
Last edit: 6 years 1 month ago by Philip.
6 years 1 month ago #322975 by MyWorld
I sent the email via the contact form.
Thanks!
6 years 1 month ago - 6 years 1 month ago #322996 by Philip
Can you provide backend access via our Contact us form please, because so far we don't understand why there are variations from products to another.
Don't forget to add as usual an Url link to this topic.
Awaiting news from you to progress on your subject.
6 years 1 month ago #323047 by MyWorld
I sent the email. Thanks in advance for your help.
6 years 1 month ago - 6 years 1 month ago #323070 by Philip
Everything is worked as expected, products that pre-selected a variant are just product which you didn't create a "select size/default" variants and define it as the default HikaShop default variant.
Note : Click to see picture details.
See the result in your product page, here
You have just to reproduce this idea for all your product.
6 years 1 month ago #323136 by MyWorld
I disagree. Unless I'm misunderstanding what you are saying.
If you look again at the 2 URLs that I sent in the email I explained that one has a default, like the example you provided above, and one does not. Yet the button is hidden for both of them on the details page.
I attached a photo of the two products for your information. Their URLs were sent in the email.
I would much prefer the option to NOT have to add a default.
Thanks!
6 years 1 month ago - 6 years 1 month ago #323142 by Philip
Now, I get it and do the required modification to all your product follow me step by step :
1. In your product backend setting, Specifications part, I add this Characteristic that you create for this purpose
2. In your frontend Css file I add a custom css to hide the Characteristics in order to be clear on the frontend side.
Without huge custom, it's a little tricks and that can be perfect but it's seems to be close to your needs.
I let you test by yourself if it fit your needs.
6 years 1 month ago #323197 by MyWorld
Sorry I created another characteristic and name it "Default" so that it's obvious as to what it's for. The other one that I was using was just to test.
Regarding Nicolas' solution below, how do I get the default characteristic to be selected automatically, so that the 2nd characteristic will show? As you can see, as per the attached image, it's not selected.
Time to create page: 0.264 seconds
