- Thank you received: 2
optional product add up issue
14 years 9 months ago #41123
by leowaqqas
optional product add up issue was created by leowaqqas
suppose we have a main product with variants and optional product.
if we leave the variants where they are and select optional product(YES), everything is fine 2 products will add to the cart.
BUT
If we select a different variant of the main product and then select optional product(YES), only one product(main) will add to the cart.
i have checked it many times and seems to be a bug somewhere.
BUT
14 years 8 months ago #41261
Replied by nicolas on topic Re: optional product add up issue
There was indeed a problem on that end that we found 1 or 2 weeks ago. Please download the install package from website and update HikaShop on your website and it should then work properly.
14 years 8 months ago #41367
by leowaqqas
Replied by leowaqqas on topic Re: optional product add up issue
hi,
i have downloaded the the package(business edition) from the website today and istalled it but its still the same. no change
14 years 8 months ago #41571
Maybe it comes from a view customization you made ?
Try to rename temporarily the folder templates/YOUR_TEMPLATE/html/com_hikashop to something else. If after that you don't have the problem, it means that it comes from a view customization.
14 years 8 months ago #41638
by leowaqqas
i have double checked the files and compared them with newly downloaded files. problem remains the same. all the files in the newly donloaded package were last modified "7th feb 2012".
14 years 8 months ago #41815
Could you give a link to the page where you have the problem so that we can see it ?
The following user(s) said Thank You: leowaqqas
14 years 8 months ago #42072
by leowaqqas
Replied by leowaqqas on topic [SOLVED] Re: optional product add up issue
hi,
replaced show and show_default from mytemplate folder with the new one and Now its fine.
thanks a lot
thanks a lot
