Menu problem with 1.5.7
14 years 8 months ago #44694 by JIK
Menu problem with 1.5.7 was created by JIK
Hi Hikashop,
Doing a fresh install and I am getting a strange menu problem with the latest release where it looks as though a language file is missing.
Please see image:
???? Any ideas???
Thanks!
14 years 8 months ago #44702 by Airbagfalte
since (update) 1.5.7 i had the same problem.
the language file is correct.
HIKA_PATH="File path"
COM_HIKASHOP_CATEGORY_VIEW_DEFAULT_TITLE="Categories listing"
COM_HIKASHOP_CHECKOUT_VIEW_DEFAULT_TITLE="Checkout"
COM_HIKASHOP_ADDRESS_VIEW_DEFAULT_TITLE="User addresses"
COM_HIKASHOP_AFFILIATE_VIEW_DEFAULT_TITLE="Affiliate program"
COM_HIKASHOP_ENTRY_VIEW_DEFAULT_TITLE="Entry registration"
COM_HIKASHOP_ORDER_VIEW_DEFAULT_TITLE="Customer orders"
COM_HIKASHOP_PRODUCT_FORM_VIEW_DEFAULT_TITLE="Product page"
COM_HIKASHOP_PRODUCT_VIEW_DEFAULT_TITLE="Products listing"
COM_HIKASHOP_USER_VIEW_DEFAULT_TITLE="Registration form"
COM_HIKASHOP_USER_PANEL_VIEW_DEFAULT_TITLE="User control panel"
COM_HIKASHOP_COMPARE_VIEW_DEFAULT_TITLE="Comparison page"
COM_HIKASHOP_CONTACT_VIEW_DEFAULT_TITLE="Contact page"
STYLES_FOR_FRONTEND="Styles for the front-end"
thanks
andré
14 years 8 months ago #44897 by nicolas
Replied by nicolas on topic Re: Menu problem with 1.5.7
Please change the line:
$menuPath = HIKASHOP_ROOT.'administrator'.DS.'language'.DS.$code.DS.$code.'.com_hikashop.menu.ini';
$menuPath = HIKASHOP_ROOT.'administrator'.DS.'language'.DS.$code.DS.$code.'.com_hikashop.ini';
in the file administrator/components/com_hikashop/helpers/update.php
and save your translation file in HikaShop's configuration.
That should fix the problem.
The following user(s) said Thank You: protorob
14 years 8 months ago #44902 by Airbagfalte
works fine... great...
thanks a lot :)
