Cart in Hikashop 2.0 does not stay on same page
14 years 1 week ago #76593 by jeremynsl
Since I upgraded to 2.0, the cart module does not stay on the current page after a product is added to it. It goes to an empty page with only the cart displayed. Also when the cart is emptied it goes to the same empty page.
I downgraded to 1.6.0 and the problem is fixed so its definitely a new bug. All settings are exactly the same between versions. And 'after a product is added to the cart' is set to 'always stay on the same page' obviously.
14 years 1 week ago #76894 by Xavier
I think that the problem could be due to a view edited on your website.
On my end it's working like a charm, when I add a product to the cart we stay on the same page.
Have you tried with our last version from the website ? Because since the first 2.0 some bugs have been fixed.
14 years 1 week ago #77079 by jeremynsl
Hi Xavier,
I don't think I've edited any cart views that I can remember.
I downloaded it again and the version is different than the last download by a few bytes. So I'll try it again and let you know.
14 years 1 week ago - 14 years 1 week ago #77815 by jeremynsl
Hi Xavier,
Today I tested the latest 2.0 download from your site... I still have the same problem.
As I said, I don't think I changed any views that I can remember. Any other ideas? (BTW I reverted back to 1.6.0 again now)
Last edit: 14 years 1 week ago by jeremynsl.
14 years 1 week ago #77911 by Xavier
And are you sure that the option in HikaShop > Checkout is still on "Stay on the same page" on something like that ? Try to save it again.
Else, I think that there is a redirection problem in the class "cart".
13 years 11 months ago #79680 by jeremynsl
Hi Xavier,
Yes, I'm sure that option is enabled. I changed the option to something else, and back again and I still have the problem.
I also noticed something else. On my 2.0 dashboard I see:
Warning: Invalid argument supplied for foreach() in .../administrator/components/com_hikashop/classes/widget.php on line 1221
I'm not sure if that's relevant or not. You guys gave me a custom widget.php to fix some problems I had with reporting in 1.6. I'm assuming that would be overwritten when I upgrade to 2.0 though.
13 years 11 months ago #79779 by nicolas
As we don't have the problem on our end, we'll have to look at it on your website or a copy of it.
Would you be able to make a copy of the updated website and provide a backend access to it so that we can look at the problem ?
13 years 11 months ago #79836 by jeremynsl
I can copy over all the website files to a new URL. But I think that they would still share the same php database. I don't know how to deal with that.
How about I give you SU access, and you can install 2.0? Once you see the problem, reinstall 1.6 for me so everything is back to normal.
13 years 11 months ago #79973 by Xavier
We prefer to do that on a copy, for the files, you can do that by ftp, and for the database you can export your current database and import it in a new database.
Then just change the settings in the config file of Joomla to change the database path.
If you can't do that, thanks to give us the SU access.
13 years 10 months ago - 13 years 10 months ago #86186 by jeremynsl
I'm sorry this took so long but I had to learn how to properly mirror my site. In the end I used Akeeba backup for the task.
So, now its done and the problem remains with 2.0. You can see it easily.
2.0 is installed to viraloutbreak.net
1.6 is installed to nucleus-soundlab.com
The ONLY difference is the 2.0 install. I have done nothing else to the nslmirror site. Now you can see the problem by going to any product page such as:
viraloutbreak.net/products/refills/new-a...llerhead-reason.html
Add the product to your cart. Then remove the product from your cart. Both actions causes Hikashop to change to a blank page. Try the same operations here:
www.nucleus-soundlab.com/products/refill...llerhead-reason.html
There are no problems with 1.6. Please help me get this fixed! Thanks,
Jeremy
Last edit: 13 years 10 months ago by jeremynsl.
13 years 10 months ago #86320 by Xavier
I think that the problem come from the return_url which is different than the base url of your website, example if the return url has "www" inside, and it's not present in the base url of your website, so hikashop don't do the redirection correctly.
Try to see in the controller product (components/com_hikashop/controllers/product.php) at the line
if(strpos($url,HIKASHOP_LIVE)===false && preg_match('#^https?://.*#',$url)) return false;
if it return false.
If yes, check is the function "strpos" return false. if it return false, that's because the both start of url are different.
13 years 10 months ago #86449 by jeremynsl
Hi Xavier,
Thanks for the reply but I don't really understand what you are asking.
Yes, in the file you ask for I do have the line below:
But I don't know how to check whether it 'returns false'. Or how to check whether the function strpos returns false. I don't have that much php knowledge.
13 years 10 months ago #86488 by Xavier
To test it, you can use this code:
var_dump($url); var_dump(HIKASHOP_LIVE); exit;
Use it just before the previous line, and on the frontend remove a product from the cart, a white page with two line should be displayed, check if the first part of the url is the same as the other url.
It must be exactly the same.
Have you changed you website url ? By adding for example "www" before the domain ? Check in the configuration.php file in the joomla files if the url is the same as the one used in the browser.
