Print Car enabled, but not displaying on front end
14 years 19 hours ago #79048 by mocana
Hello Hika community!
We have a website at : farmerthydro.com and are working to be close to completion. We are having an issue though with the 'Print Cart' function. It is enabled through the configuration but is not showing up on the front end. the client does indeed want this to be set up so that a user can print out their cart and perform a will call order.
Please help!
14 years 17 hours ago #79074 by Jerome
If you want to print your cart, you have to open the cart page.
farmerthydro.com/index.php?option=com_hikashop&ctrl=cart
14 years 12 hours ago #79136 by mocana
That was it! Thank you! Also, for your reference too, I was able to Copy the link location and make a Custom HTML Module above the cart itself!!! More user friendly – FarmerTHydro.com
Thank you for the quick response!
13 years 11 months ago #79366 by Ch3vr0n
Just for the sake of checking i clicked on that url & went to the site & tried to print an empty cart by clicking on the link. Doing so resulted in the following error
Warning: Invalid argument supplied for foreach() in /home/content/m/a/r/marksidea/html/farmert/administrator/components/com_hikashop/classes/cart.php on line 1467
The cart is empty
It seems that this is similar to mine
www.hikashop.com/forum/3-bug-report/7622...d.html?lang=en#79363
Warning: Invalid argument supplied for foreach() in /home/xxxxx/domains/xxxx.xx/public_html/administrator/components/com_hikashop/classes/cart.php on line 1465
looks like there is something wrong with the cart file
13 years 11 months ago #79391 by Xavier
I don't have the same things on the line 1465, so I hope that my solution is for the good problem, try to add a if like that:
if(isset($cart->products) && $cart->products != null){ // foreach{ ... } }
Around the foreach on the line 1465 of that file.
