System using Wishlist and causing 500 error
13 years 8 months ago #95283 by brentwilliams2
I upgraded from 2.0.0 to 2.1.1 and everything seemed to go fine, but now, on random occasions, instead of giving the option to "Proceed to checkout" to the user, it instead says "show the wishlists". When the user clicks on that button, it sends them to an error page: www.multifamilyinsiders.com/shop-multifa...showcarts/cart_type-
This behavior seems to be random, and I have wishlists turned off in the following location:
  • Display > Display 'Add to wishlist' button
However, the option "Checkout > Display the convert cart in wishlist button" is neither No or Yes - I am unable to change that setting.
Any help? Right now, the cart is unusable half the time.
The following user(s) said Thank You: mt_robson
13 years 8 months ago #95324 by Xavier
There is an error when loading your website.
Have you edited the view "checkout / notice" in HikaShop > Display > Views ?
13 years 8 months ago #95339 by brentwilliams2
Can you tell me what error you are getting when going on the site? I'm not seeing it.
And no, I have not edited that view.
13 years 8 months ago #95343 by Xavier
Address not found.
Firefox can't found the server at the address www.multifamilyinsiders.com/
13 years 8 months ago #95366 by brentwilliams2
Well... this is frustrating - I clicked on the link you just typed and it comes up fine for me. It loads up when I check with www.webpagetest.org .
13 years 8 months ago #95410 by Xavier
Ok, I can reach your website now.
When clicking on "add to cart" button, the cart type sent is "cart" so it's ok, but the notice view have a "wishlist" type.
I'm not able to reproduce the problem on my end, could you give us a backend and ftp access ?
13 years 8 months ago #95477 by brentwilliams2
I just messaged you details - thank you!
13 years 8 months ago #95482 by Xavier
I turned off the option "Enable the wishlists" in Configuration > Features > Wishlists and it seems to be working fine.
Thanks to confirm :)
13 years 8 months ago #95484 by brentwilliams2
I didn't realize there were so many places wishlists were included in the configuration settings.
I'll let you know if I see the issue again.
Thank you! Can you message me how much I owe you and how to pay?
13 years 8 months ago #95487 by Xavier
For only an option, it's free ;)
Waiting for your feedback.
13 years 8 months ago #96389 by brentwilliams2
Hi Xavier,
Unfortunately, it looks like the issue is still there. It is random, so it doesn't show up all the time, but it is present.
13 years 8 months ago #96437 by Xavier
Could you give me a backend access ? (the old one seems to be deleted)
13 years 8 months ago #96473 by mt_robson
I assume I have the same problem as follows:
When customers try to add the first article to their cart, they receive this Popup Notice (Screenshot 1).
Clicking on "Display the Wishlists" results in Error 500 (Screenshot 2), clicking on "Continue" instead usually works fine.
In contrary to what brentwilliams2 experienced it is not random with me; from the second article added on it works fine (Screenshot 3).
I (currently) do not need wishlists at all (I hopefully have turned them off correctly in the settings), but I desperately need my cart function working properly :( .
Thx in advance for your help,
Matt B) .
www.buch-comptoir.de
shop.buch-comptoir.de
[Weltweiter Versand seltener Bücher]
13 years 8 months ago #96530 by brentwilliams2
Xavier, you should have access again - sorry about that.
And Matt, I think you are actually correct. Now that I look at it again, it might now be 1st time wishlist, 2nd+ time is the proper checkout button.
13 years 8 months ago #96534 by Xavier
I have applied a patch on your website, thanks to confirm if that have corrected the bug.
The view "checkout / notice" have to be replaced by:
<?php /** * @package HikaShop for Joomla! * @version 2.1.1 * @author hikashop.com * @copyright (C) 2010-2012 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php $app = JFactory::getApplication(); $wishlist_id = $app->getUserState( HIKASHOP_COMPONENT.'.wishlist_id','0'); $cart_type = $app->getUserState( HIKASHOP_COMPONENT.'.popup_cart_type','cart'); $app->setUserState( HIKASHOP_COMPONENT.'.popup_cart_type','cart'); ?> <script type="text/javascript"> setTimeout( 'window.parent.hikashop.closeBox()', <?php echo (int)$this->config->get('popup_display_time',2000);?> ); </script> <div id="hikashop_notice_box_content" class="hikashop_notice_box_content" > <div id="hikashop_notice_box_message" > <?php if($cart_type == 'wishlist'){ echo hikashop_display(JText::_('PRODUCT_SUCCESSFULLY_ADDED_TO_WISHLIST'),'success',true); }else{ echo hikashop_display(JText::_('PRODUCT_SUCCESSFULLY_ADDED_TO_CART'),'success',true); } ?> </div> <br /> <div id="hikashop_add_to_cart_continue_div"> <?php echo $this->cartClass->displayButton(JText::_('CONTINUE_SHOPPING'),'continue_shopping',$this->params,'','window.parent.hikashop.closeBox(); return false;','id="hikashop_add_to_cart_continue_button"'); ?> </div> <?php if($cart_type == 'wishlist'){ ?> <div id="hikashop_add_to_cart_checkout_div"> <?php if($wishlist_id != 0) echo $this->cartClass->displayButton(JText::_('DISPLAY_THE_WISHLIST'),'wishlist',$this->params,hikashop_completeLink('cart&task=showcart&cart_id='.$wishlist_id.'&cart_type='.$cart_type.$this->url_itemid),'window.top.location = \''.hikashop_completeLink('cart&task=showcart&cart_id='.$wishlist_id.'&cart_type='.$cart_type.$this->url_itemid).'\';return false;'); else echo $this->cartClass->displayButton(JText::_('DISPLAY_THE_WISHLISTS'),'wishlist',$this->params,hikashop_completeLink('cart&task=showcarts&cart_type='.$cart_type.$this->url_itemid),'window.top.location = \''.hikashop_completeLink('cart&task=showcarts&cart_type='.$cart_type.$this->url_itemid).'\';return false;'); ?> </div> <?php } else{ ?> <div id="hikashop_add_to_cart_checkout_div"> <?php echo $this->cartClass->displayButton(JText::_('PROCEED_TO_CHECKOUT'),'to_checkout',$this->params,hikashop_completeLink('checkout'.$this->url_itemid),'window.top.location=\''.hikashop_completeLink('checkout'.$this->url_itemid).'\';return false;','id="hikashop_add_to_cart_checkout_button"'); ?> </div> <?php } ?> </div>
13 years 8 months ago #96579 by brentwilliams2
Looking good so far! I'll let you know if I see it again.
Thanks!
13 years 7 months ago #99896 by mt_robson
Hello Xavier,
this also worked out nicely - even "wunderbar" ;).
Your support is just great - thx a lot!
Cheers,
M. :)
Time to create page: 0.132 seconds
