VAT problem
13 years 8 months ago #96613 by mohairbears
VAT problem was created by mohairbears
Hi, I need to now include VAT. Is it possible to leave my current product prices (including VAT) and display the VAT total in checkout?
i.e. product price 5.00 including VAT checkout to display 4.17 in Order Total, and .83 in VAT @ 20%, Final Total 5.00
If this cannot be done what is the best way for me to proceed to set up VAT considering I have 1000's of products with prices that include the forthcoming VAT (April 1st)?
thanks in advance
13 years 8 months ago #96620 by Mohamed Thelji
Replied by Mohamed Thelji on topic VAT problem
I think that the best way to do that would be to add a tax rate to your "default tax category", then this tax should be applied to all your products.
Hope this will help you a little.
13 years 8 months ago #96621 by mohairbears
Replied by mohairbears on topic VAT problem
Sorry but this is not what I want to do as explained, by doing that it will add a further 20% to the already set prices.
13 years 8 months ago #96628 by Mohamed Thelji
Ok, so can you explain your problem with more detail, through some screenshots for example ?
13 years 8 months ago #96632 by mohairbears
Ok I'll try.
I have been using Hikashop for quite a few years and did not pay VAT as we have been below the threshold.
Our current product prices would need to stay the same (to remain competitive) therefore we have prices shown as including VAT, BUT!
Is it possible to show the 20% part of the total as VAT in Checkout as below.
Order Total £100
VAT @ 20% £20
Shipping £7
Final Total £107
The only way I can see to do this is to reduce our prices by 20% and as there are 1,000's then this is going to be a very time consuming job so we are looking for a quicker solution if there is one.
thanks
13 years 8 months ago #96641 by Mohamed Thelji
Sure, you'll just have to :
- Go to "Hikashop->System->Configuration->'Main'->'Taxes'"
- Set the "Show taxed prices" to no tax
Then your product will display without any tax through the product page and the checkout, but you'll have a "VAT" line trough the checkout like you wanted to.
13 years 7 months ago #96748 by mohairbears
Hi, this does work as you say BUT the VAT is added in the Final Total, I do not want it added to the final total as it already has been added?
thanks
13 years 7 months ago #96784 by Mohamed Thelji
Ok, So if you want to change the way your cart is displaid, you'll have to do it through "Hikashop->Display->Views" by editing the code of your cart file of your checkout view of your front-end template.
13 years 7 months ago #96818 by mohairbears
Ok so which part of the code needs changing? as this is dragging on can you please ask Nik as he will advise.
All I want is the HIKASHOP_FINAL_TOTAL to NOT include the VAT in it's calculation, I want the VAT total displayed though.
thanks
13 years 7 months ago #96913 by nicolas
Replied by nicolas on topic VAT problem
You cannot have the VAT calculated from the taxed price. VAT is always calculated from the untaxed price.
So your calculations are wrong. If the total taxed is 100£ and that the tax is 20%, the tax amount is not 20£ but 16.67£ and the untaxed price is not 80£ but 83.33£
So you need to have the untaxed price in all your products and then set the tax rules to add the 20% VAT to get back your normal product prices.
Fortunately, changing all the prices at once is quite easy with a SQL query.
Simply run the query below in your phpmyadmin to remove the VAT from your product prices:
UPDATE #__hikashop_price SET price_value=price_value/1.2
(make sure that you replace #__ by your table prefix)
13 years 7 months ago #96919 by mohairbears
Wicked I knew you would give me the solution.
thanks
