Discount being applied to individual products
12 years 6 months ago #156246 by optimized
-- url of the page with the problem -- : starsupplyalliance.com
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.2
-- PHP version -- : 5.4
I need the discount to be applied to the total purchase amount not the individual products purchased. I have used the Orders / Discounts /Coupons set up as advised and I attach a screen shot of one of the coupons.
How do I get the coupon to reflect the total amount in the cart?
Many thanks,
Mike
12 years 6 months ago #156286 by lousyfool
Reads like you haven't configured the coupon properly.
Go into the discount/coupon and check the settings. There's one where the on-board help says, "Coupon percentage applies to product only : When a percentage is entered for the coupon and that a product or a category is selected for the coupon, if you activate that option, the coupon value will be based on the price of that product in the cart or on the sum of prices of all the products of the cart which are in that category."
If it's all set okay, the coupon will apply not to a single product, but to the (sub)total of the cart, means all items in the cart, before shipping.
Still unsure? Then click on "Help" in the toolbar while there...
12 years 6 months ago #156261 by nicolas
We didn't get any screenshot in your message. Could you try again to attach it please ?
Without knowing how the coupon is setup it's hard to say what could be wrong.
12 years 6 months ago #156407 by optimized
Hi guys,
I attach the screenshot of the coupon set up and the complete coupon list.
I have the Category set to 2 product category
Whether I set Coupon percentage applies to product only to Yes or No the discount applies 10% which is the $1000 bracket coupon rather than the 15%
How do I get the 15% discount on the total?
Thanks,
Mike
12 years 6 months ago #156449 by nicolas
I would recommend to remove the category selection and turn off the option " Coupon percentage applies to product only" so that it applies to the total purchased order. Make sure that you do that for all the coupons.
It should work fine then.
12 years 6 months ago #156567 by optimized
I followed your instructions and now the cart seems to me calculating the discount across the whole cart correctly but it seems to be only using the lowest rate of 5% to make the discount even when the order is above $1000 which should give a rate of 10% - see screenshots.
What could be causing this issue?
Thanks,
Mike
12 years 6 months ago #156573 by Mohamed Thelji
Hello Mike,
I think that you should also set a "Maximum order value" for your coupons like 599.99 for your 5% coupon.
12 years 6 months ago #156739 by optimized
Hello Mohamed,
Your suggestion makes sense to me but I cannot see this option - see attached screenshot.
Please advise.
Thanks,
Mike
12 years 6 months ago #156877 by Xavier
There is indeed not this option for the coupons.
I have reproduced the issue on my local. I add in the todo list to debug that as soon as possible.
We will keep you informed. Thanks for the report.
12 years 5 months ago #158353 by Xavier
We have solved this problem, it will be available in the next release.
To correct it now, thanks to edit the file "administrator/components/com_hikashop/classes/cart" and replace the function "loadFullCart()" by the following code:
function &loadFullCart($additionalInfos=false,$keepEmptyCart=false,$skipChecks=false){ $app = JFactory::getApplication(); $database = JFactory::getDBO(); $config =& hikashop_config(); $currencyClass = hikashop_get('class.currency'); $productClass = hikashop_get('class.product'); $main_currency = (int)$config->get('main_currency',1); $currency_id = hikashop_getCurrency(); if(!in_array($currency_id,$currencyClass->publishedCurrencies())){ //if the selected currency can't be used for checkout use the main currency $currency_id = $main_currency; } $zone_id = hikashop_getZone('shipping'); if($config->get('tax_zone_type','shipping')=='billing'){ $tax_zone_id=hikashop_getZone('billing'); }else{ $tax_zone_id=$zone_id; } $discount_before_tax = (int)$config->get('discount_before_tax',0); $cart = new stdClass(); $cart->products = $this->get(@$this->cart->cart_id, $keepEmptyCart); $cart->cart_id = (int)@$this->cart->cart_id; $cart->cart_type = @$this->cart->cart_type; $cart->cart_params = @$this->cart->cart_params; $cart->coupon = null; $cart->shipping = null; $cart->total = null; $cart->additional = array(); if(!empty($cart->products)){ $ids = array(); foreach($cart->products as $product){ $ids[]=$product->product_id; } JArrayHelper::toInteger($ids); $query = 'SELECT * FROM '.hikashop_table('file').' WHERE file_ref_id IN ('.implode(',',$ids).') AND file_type IN( \'product\',\'file\') ORDER BY file_ref_id ASC, file_ordering ASC'; $database->setQuery($query); $images = $database->loadObjectList(); if(!empty($images)){ foreach($cart->products as $k => $row){ $productClass->addFiles($cart->products[$k],$images); } } //add variants inside main products as reference for tax calculus foreach($cart->products as $k => $row){ if($row->product_type=='variant'){ foreach($cart->products as $k2 => $row2){ if($row->product_parent_id==$row2->product_id){ $cart->products[$k2]->variants[]=&$cart->products[$k]; break; } } } } //add the characteristics infos $query = 'SELECT a.*,b.* FROM '.hikashop_table('variant').' AS a LEFT JOIN '.hikashop_table('characteristic').' AS b ON a.variant_characteristic_id=b.characteristic_id WHERE a.variant_product_id IN ('.implode(',',$ids).') ORDER BY a.ordering,b.characteristic_value'; $database->setQuery($query); $characteristics = $database->loadObjectList(); if(!empty($characteristics)){ foreach($cart->products as $key => $product){ if($product->product_type!='variant'){ $element =& $cart->products[$key]; $product_id=$product->product_id; $mainCharacteristics = array(); foreach($characteristics as $characteristic){ if($product_id==$characteristic->variant_product_id){ $mainCharacteristics[$product_id][$characteristic->characteristic_parent_id][$characteristic->characteristic_id]=$characteristic; } if(!empty($element->options)){ foreach($element->options as $k => $optionElement){ if($optionElement->product_id==$characteristic->variant_product_id){ $mainCharacteristics[$optionElement->product_id][$characteristic->characteristic_parent_id][$characteristic->characteristic_id]=$characteristic; } } } } if(!empty($element->variants)){ $this->addCharacteristics($element,$mainCharacteristics,$characteristics); } if(!empty($element->options)){ foreach($element->options as $k => $optionElement){ if(!empty($optionElement->variants)){ $this->addCharacteristics($element->options[$k],$mainCharacteristics,$characteristics); } } } } } } //calculate prices $product_quantities = array(); foreach($cart->products as $row){ if(empty($product_quantities[$row->product_id])){ $product_quantities[$row->product_id] = (int)@$row->cart_product_quantity; }else{ $product_quantities[$row->product_id]+=(int)@$row->cart_product_quantity; } if(empty($product_quantities[$row->product_parent_id])){ $product_quantities[$row->product_parent_id] = (int)@$row->cart_product_quantity; }else{ $product_quantities[$row->product_parent_id] += (int)@$row->cart_product_quantity; } } foreach($cart->products as $k => $row){ $cart->products[$k]->cart_product_total_quantity = $product_quantities[$row->product_id]; if($row->product_parent_id){ $cart->products[$k]->cart_product_total_variants_quantity = $product_quantities[$row->product_parent_id]; }else{ $cart->products[$k]->cart_product_total_variants_quantity = $cart->products[$k]->cart_product_total_quantity; } } $currencyClass->getPrices($cart->products,$ids,$currency_id,$main_currency,$tax_zone_id,$discount_before_tax); if($additionalInfos){ $queryImage = 'SELECT * FROM '.hikashop_table('file').' WHERE file_ref_id IN ('.implode(',',$ids).') AND file_type=\'product\' ORDER BY file_ref_id ASC, file_ordering ASC, file_id ASC'; $database->setQuery($queryImage); $images = $database->loadObjectList(); foreach($cart->products as $k=>$row){ if(!empty($images)){ foreach($images as $image){ if($row->product_id==$image->file_ref_id){ if(!isset($row->file_ref_id)){ foreach(get_object_vars($image) as $key => $name){ $cart->products[$k]->$key = $name; } } break; } } } if(!isset($cart->products[$k]->file_name)){ $cart->products[$k]->file_name = $row->product_name; } } } foreach($cart->products as $k => $row){ if(!empty($row->variants)){ foreach($row->variants as $k2 => $variant){ $productClass->checkVariant($cart->products[$k]->variants[$k2],$row); } } } //check that products are still published etc $notUsable = array(); $cartData = $this->loadCart($cart->cart_id); if(!$skipChecks){ $cart->products = array_reverse($cart->products); foreach($cart->products as $k => $product){ if(empty($product->product_id)){ continue; } if(!empty($product->cart_product_quantity)){ $oldQty = $product->cart_product_quantity; if(@$cartData->cart_type != 'wishlist') $this->_checkQuantity($product,$product->cart_product_quantity,$cart->products,$product->cart_product_id); if($oldQty!=$product->cart_product_quantity){ $notUsable[$product->cart_product_id]=0; break; } if(!$config->get('display_add_to_cart_for_free_products',0) && empty($product->prices)){ $notUsable[$product->cart_product_id]=0; $app->enqueueMessage(JText::sprintf('PRODUCT_NOT_AVAILABLE',$product->product_name),'notice'); continue; } if(empty($product->product_published)){ $notUsable[$product->cart_product_id]=0; $app->enqueueMessage(JText::sprintf('PRODUCT_NOT_AVAILABLE',$product->product_name),'notice'); continue; } if($product->product_quantity!=-1 && $product->product_quantity < $product->cart_product_quantity){ $notUsable[$product->cart_product_id]=0; $app->enqueueMessage(JText::sprintf('NOT_ENOUGH_STOCK_FOR_PRODUCT',$product->product_name),'notice'); continue; } if($product->product_sale_start>time()){ $notUsable[$product->cart_product_id]=0; $app->enqueueMessage(JText::sprintf('PRODUCT_NOT_YET_ON_SALE',$product->product_name),'notice'); continue; } if(!empty($product->product_sale_end) && $product->product_sale_end<time()){ $notUsable[$product->cart_product_id]=0; $app->enqueueMessage(JText::sprintf('PRODUCT_NOT_SOLD_ANYMORE',$product->product_name),'notice'); continue; } } } $cart->products = array_reverse($cart->products); } if(!empty($notUsable)){ //if we need to remove products from the cart do so and then reload the cart $this->update($notUsable,1,0,'item'); return $this->loadFullCart($additionalInfos); } foreach($cart->products as $k => $row){ //we unset the cart coupon and modified date in order to avoid the auto load hash on the products to be different if only the coupon of the cart changed unset($cart->products[$k]->cart_modified); unset($cart->products[$k]->cart_coupon); $currencyClass->calculateProductPriceForQuantity($cart->products[$k]); } $currencyClass->calculateTotal($cart->products,$cart->total,$currency_id); $cart->full_total=&$cart->total; JPluginHelper::importPlugin('hikashop'); JPluginHelper::importPlugin('hikashoppayment'); JPluginHelper::importPlugin('hikashopshipping'); $dispatcher = JDispatcher::getInstance(); $dispatcher->trigger('onAfterCartProductsLoad', array( &$cart ) ); if(!empty($cart->additional)) { $currencyClass->addAdditionals($cart->additional, $cart->additional_total, $cart->full_total, $currency_id); $cart->full_total =& $cart->additional_total; } if(!empty($this->cart->cart_coupon) && $cart->cart_type != 'wishlist'){ $discount=hikashop_get('class.discount'); $discountData = $discount->load($this->cart->cart_coupon); if(@$discountData->discount_auto_load){ $current_auto_coupon_key = sha1($zone_id.'_'.serialize($cart->products).'_'.hikashop_loadUser()); $previous_auto_coupon_key = $app->getUserState( HIKASHOP_COMPONENT.'.auto_coupon_key'); if($current_auto_coupon_key!=$previous_auto_coupon_key){ $this->cart->cart_coupon=''; } } } if(hikashop_level(1) && empty($this->cart->cart_coupon) && $cart->cart_type != 'wishlist'){ $filters = array('discount_type=\'coupon\'','discount_published=1','discount_auto_load=1'); hikashop_addACLFilters($filters,'discount_access'); $query = 'SELECT * FROM '.hikashop_table('discount').' WHERE '.implode(' AND ',$filters).' ORDER BY discount_minimum_order DESC, discount_minimum_products DESC'; $this->database->setQuery($query); $coupons = $this->database->loadObjectList(); if(!empty($coupons)){ $discount = hikashop_get('class.discount'); $zoneClass = hikashop_get('class.zone'); $zones = $zoneClass->getZoneParents($zone_id); foreach($coupons as $coupon){ $result = $discount->check($coupon,$cart->total,$zones,$cart->products,false); if($result){ //if we found a coupon to auto load add the coupon to the cart and reload the cart $auto_coupon_key = sha1($zone_id.'_'.serialize($cart->products).'_'.hikashop_loadUser()); $app->setUserState( HIKASHOP_COMPONENT.'.auto_coupon_key',$auto_coupon_key); $app->setUserState( HIKASHOP_COMPONENT.'.coupon_code',''); $this->update($coupon->discount_code,1,0,'coupon',true); if(empty($this->cart)) $this->cart= new stdClass(); $this->cart->cart_coupon = $coupon->discount_code; static $done = false; if($done == false){ $done = true; return $this->loadFullCart($additionalInfos); } } } } } if(!empty($this->cart->cart_coupon) && $cart->cart_type != 'wishlist') { $zoneClass = hikashop_get('class.zone'); $zones = $zoneClass->getZoneParents($zone_id); $cart->coupon = $discount->loadAndCheck($this->cart->cart_coupon, $cart->full_total, $zones, $cart->products, true); if(empty($cart->coupon)) { if(!empty($this->cart)) $this->cart->cart_coupon = ''; } else { $cart->full_total = &$cart->coupon->total; } } if(bccomp($cart->full_total->prices[0]->price_value_with_tax, 0, 5) <= 0) { $cart->full_total->prices[0]->price_value_with_tax = 0; $cart->full_total->prices[0]->price_value = 0; if(isset($cart->full_total->prices[0]->taxes)) unset($cart->full_total->prices[0]->taxes); } $shipping_id = $app->getUserState(HIKASHOP_COMPONENT.'.shipping_id'); if(!empty($shipping_id)) { $cart->shipping = $app->getUserState(HIKASHOP_COMPONENT.'.shipping_data'); if(!empty($cart->shipping)) { if(!is_array($cart->shipping)){ $cart->shipping = array($cart->shipping); }else{ //make sure that there are no shipping methods entered twice in the selected shipping data. $shippings = array(); foreach($cart->shipping as $method){ $group_key = $method->shipping_id; if(!empty($method->shipping_warehouse_id)){ $group_key .= '_'; if(is_array($method->shipping_warehouse_id)){ foreach($method->shipping_warehouse_id as $key => $val){ $group_key .= $key.$val; } }else{ $group_key .= $method->shipping_warehouse_id; } } $shippings[$group_key]=$method; } $cart->shipping = array_values($shippings); } $currencyClass = hikashop_get('class.currency'); $shipping =& $cart->shipping; $currencyClass->processShippings($shipping,$cart); //calculate total price with shipping $cart->full_total =& $currencyClass->addShipping($cart->shipping, $cart->full_total); } } $before_additional = !empty($cart->additional); $dispatcher->trigger('onAfterCartShippingLoad', array( &$cart ) ); if(!$before_additional && !empty($cart->additional)) { $currencyClass->addAdditionals($cart->additional, $cart->additional_total, $cart->full_total, $currency_id); $cart->full_total =& $cart->additional_total; } if(bccomp($cart->full_total->prices[0]->price_value_with_tax,0,5)<=0){ $cart->full_total->prices[0]->price_value_with_tax = 0; $cart->full_total->prices[0]->price_value = 0; if(isset($cart->full_total->prices[0]->taxes)) unset($cart->full_total->prices[0]->taxes); } $payment_id = $app->getUserState( HIKASHOP_COMPONENT.'.payment_id'); if(!empty($payment_id)){ $cart->payment = $app->getUserState( HIKASHOP_COMPONENT.'.payment_data'); if(!empty($cart->payment)){ $currencyClass = hikashop_get('class.currency'); $payment =& $cart->payment; $payments = array(&$payment); $currencyClass->processPayments($payments); //calculate total price with payment $currencyClass->addPayment($cart->payment,$cart->full_total); $cart->full_total=&$cart->payment->total; } } } if($additionalInfos){ $app = JFactory::getApplication(); $shipping_address=$app->getUserState( HIKASHOP_COMPONENT.'.shipping_address',0); if(!empty($shipping_address)){ $this->loadAddress($cart,$shipping_address); } $billing_address=$app->getUserState( HIKASHOP_COMPONENT.'.billing_address',0); if($billing_address==$shipping_address){ $cart->billing_address =& $cart->shipping_address; }else{ if(!empty($billing_address)){ $this->loadAddress($cart,$billing_address,'parent','billing'); } } $this->calculateWeightAndVolume($cart); } return $cart; }
12 years 5 months ago #158461 by optimized
Hi Xavier,
Thanks very much for this.
However, I cannot find the string loadFullCart() to replace it in cart.php.
Please advise.
Mike
12 years 5 months ago #158898 by nicolas
Please do that modification and it should fix the problem:
www.hikashop.com/forum/product-category-...orrectly.html#158811
12 years 5 months ago #158977 by optimized
Hello Nicolas,
I installed the fix but the discounts re still not working properly at starsupplyalliance.com/ (see attached screenshot for coupon levels.
For example,
- there is no discount applied for sales between $300 and $600
- an incorrect discount of 10% is applied between sales of $600- $1000
Mohamed Thelji has staed in this thread that
'I think that you should also set a "Maximum order value" for your coupons like 599.99 for your 5% coupon. ' which is still not possible after the patch.
Please advise on how to make these calculations work.
Mike
12 years 5 months ago #159704 by optimized
Hi guys,
Is there any movement on this issue?
Thanks,
Mike
12 years 5 months ago #159759 by nicolas
Sorry for the delay.
We've add to apply multiple patches to fix that.
Replace the files discount.php and cart.php in the folder administrator/components/com_hikashop/classes with the ones in this archive and that should solve definitely the issue:
12 years 5 months ago #159833 by optimized
Thanks for this - it is looking much better.
The only problem we have now is that the doscount is being applied to the post tax price rather than the pre-tax which is what we need - how do we use the pre-tax value?
Mike
12 years 5 months ago #159881 by nicolas
You have the option "Apply discounts" of the configuration if you want to change that.
12 years 5 months ago #159992 by optimized
Your responses are normally very clear but I don't understand this one.
I want to change the calculation so that the discount is applied to the pre-tax amount.
Where in the configuration do I set this up?
Thanks,
Mike
12 years 5 months ago #159997 by nicolas
I don't see where my answer was not clear ?
Toggle the "Apply discounts" option of the configuration and that will do it:
take.ms/bwuZU
12 years 5 months ago #160126 by optimized
I was looking everywhere bar the obvious place!
As you can see from the first attachment, the tax/discount is set up as you recommended but as you can see from screenshot 2 the discount is being applied on the post tax amount.
Mike
Time to create page: 0.109 seconds
